Norville
- Joined
- Dec 19, 2022
- Messages
- 27
- Likes
- 4
Hi!
I'm new to this forum and this is my first post. I have been reading quite a lot of threads here and I really respect the wealth of knowledge that can be found here. However, there are a few things that I cannot find a proper answer to so I figured I'll ask them here.
I have an Asus ZenFone which I use an external USB DAC dongle with to listen to local files and Tidal with using mostly my LetShuoer S12 iems. My problem is that after I dropped my phone, the phone took a hit and now the volume rocker buttons doesn't work properly so I can only raise the volume with them and then I have to use the software slider to adjust the volume down. The repair would be expensive and the phone works flawlessly otherwise so I have solved this by ordering a DAC dongle with hardware volume buttons, the Tempotec Sonata HD III. I haven't got it yet so I'm hoping the volume Control with this will work good. Does anyone know how many volume steps this dongle have? Will I be able to control the volume on Hiby music by only using the volume buttons if I lock the volume in Hiby?
Another problem is, if I go to the home screen in ny phone I can't control the volume of Hiby music in the Android system slider, I have to go back to Hiby to set the volume. This doesn't happen if I don't use USB exclusive mode. Is this the way it's supposed to work?
If I use UAPP, then I can control the volume outside the app, but this doesn't work in Hiby music, which is sad because I much prefer Hiby music app.
Yikes, that was a lot of questions, I hope someone will be able to answer them.
