Hiby FC3 Portable DAC & HP Amp Review
Rate this DAC & HP Amp
    Votes: 1 0.7%
    Votes: 15 11.2%
    Votes: 97 72.4%
    Votes: 21 15.7%
This is a review and detailed measurements of the Hiby FC3 portable headphone amplifier and DAC. It is on kind loan from a member and costs US $59 on company website.
As you see, this is an attractive dongle. The reverse side is even nicer as it sports a high resolution OLED display that legibly shows the sampling rate and current volume (goes off automatically). Alas, there is a miss in not having auto repeat on up and down volume controls if you hold them down.
Hiby FC3 Measurements
I set the volume to max and here is our dashboard output:
Performance is bound by distortion. Still, the results land in competent category for all portable dongles tested:
Since distortion is the problem, lowering the volume improves things:
Noise is very much under control:
Jitter shows some sidebands but they are not the audible kind:
Power is almost everything in portable devices so let's measure that:
300 ohm measurement is voltage limited so devices that output 4 volts (in "balanced" mode) bean the FC3 but otherwise, performance is good. As noted, more output could be had if the gain was higher as there is no clipping.
Conversely at 32 ohm, we are current limited:
The Hiby FC3 is one of the nicest looking dongles I have tested. Price is reasonable and performance is very good. The only thing that would make it better would have been balanced output of 4 volts.
I am going to recommend the Hiby FC3 portable DAC and headphone amplifier.
Very nice review! I kind of expected this performance.
Any way you can run linearity? Or does the test not work with dongles?
My pleasure. Can't run linearity because AP can't properly feed these dongles by itself. Most of the tests results were generated by having Roon play the test track and AP just measuring.
Ah! I figured there was a reason you don't have linearity on the dongle tests.
If I’m not mistaken, this is build around the ES9281 Pro codec from ESS.
Any chance to test the ADC input? Per Spec Sheet, it should be capable of 88dB THD+N… Better than the typical PC input, I think.
I think there may be a mix up between these variants and their pricing. It sounds like the one tested is the more expensive one with the display, not the cheaper one without.
https://store.hiby.com/products/hiby-fc3 - currently $39
https://store.hiby.com/products/hiby-fc3-with-display - currently $59
Both support mic input following the CTIA pinout.
Yes, it is the "with display" new variant as @amirm stated:
so posted specs should be updated to the correct one
Thank you for the review, I was tempted to buy one a while ago during Aliexpress sales since I consider display to be a big added value for dongles with volume button controls, but it seems that implementing ESS9281 is not as easy as CS43131, since performance on paper should be better than what measurements say.
I ended up buying a balanced Tempotec Sonata BHD for even less (on sale) and I'm pretty happy with it.
Surely still a good option for anyone needing mic input, ADC measurements would be appreciated.
Why is the Tanchjim Space dongle not visible in the overview of dongles like this one. What is the difference in catagory of both?
In that case, the FC4 when on sale (often) for $59 seems like a great alternative with 4.4 balanced output and 110mW on the 3.5mm output vs the FC3 with 70mW output
I already have too many inexpensive dongles that perform well. It's amazing how much performance you can get in the $40 to $60 range. The Apple dongle is absolutely wonderful but doesn't produce the voltage that these do. I use mine more for feeding line level inputs than headphones so the 2V is important to me. My phone sounds great in the car plugged into the aux input.
It is the $59 version, that is correct.
I also forgot it does have a mic input! I didn't use it when I tested it but it was one of the reasons I bought it.
The performance exceeds what many desktop units gave us just 7 years ago... Thankfully the industry today has changed and while this is competent, it doesn't even land near the top! Really great work done here with this forum as manufacturers haven't been able to get away with producing junk.
