Your ears must just not be resolving enough... There I said it...
This only shows that to you at least, the MTM is an acceptable compromise. That does not mean that it is true for everyone.
Ha-ha, perhaps that is true. But in order to make that statement you would need to know a few things:
1. The seating positions (the angles in my home)
2. The dispersion issue with the speaker itself
3. The dispersion issue within my room
4. The additional sound changes that being enclosed in a cabinet may add along with the cover
5. The impact of room correction (it cannot overcome the inherent measurement issues but it will change the sound)
6. The vertical elevation of the speaker to the ears
I know the answers to some of these and I'm the only who has heard the speaker in my room.
And the most important question would be is my MTM a 2.5 way speaker?
Apparently, that happens to be the case with my center channel. I didn't know that until 1 minute ago. Apparently, my ears have gone from not being resolving enough to being able to detect a 2.5 way system and stay true to my decision for 20 years.
Does that not turn it into a WMTW or WTMW design depending on the woofer handling midrange?
Perhaps, I should be nominated for the Nobel Prize for hearing
Liking something for 20 years doesn’t make its limitations disappear. It just means you adapted to them.
On the scale of adaptation, I'd rank myself as the president emeritus of the non-adaptation club. But that might be subjective.
That is factually incorrect. MTM centers have been called out for decades because of their limitations. That is why they are currently basically non-existent in anything other than the lowest budget of speaker lines.
Here's an article by Gene and I'll quote his conclusion below:
This article contains an in depth discussion of the trade-offs of different center channel designs (MTM vs WTMW, etc) and their real world applications and limitations.
www.audioholics.com
MTM and W(T/M)W are the two basic center channels designs that are most popular. There are many variants of each all with their associated strengths and weaknesses. The best advice one could give when choosing a center channel speaker or any of the speakers in your theater room is to NOT just blindly rule out a particular type of design because someone says it theoretically cannot work. Test them with your ears in your listening environment across your listening area to decide if they are right for you.
The last sentence is essentially the whole point here - "test them with your ears in your listening environment across your listening area to decide if they are right for you".
I would say that a huge number of home theater center channels have MTM designs and I would not be surprised if soundbars have them too. It's a bit elitist to say that it's only for the lowest budget of speakers when the majority of folks may only be able to afford those.
