Hi would adding a external DAC to the wiim ultra streamer make a difference/improve sound?
J84
Hi would adding a external DAC to the wiim ultra streamer make a difference? Like will it improve the music/sound to worth spending on a external DAC?
The DAC I'm looking at is the topping D90 111 sabre listed at £899.
Set up will be -
Speaker - Wharfedale Linton, Amp - 2×Topping B200, Streamer - wiim ultra, Subwoofer - SVS PB2000 Pro or SVS SB2000 pro
Do I need to add a external DAC to the setup?
If it’s this,
Then no, unless you wish to add distortion.
As said above, you won't improve your sound by adding a DAC. The WiiM is already better than you can hear.
Second the suggestion to get a measurement microphone to use with your WiiM's roomfit feature.
Nice system, enjoy
If it’s this,
Thanks
Wiim ultra's dac is excellent. Nice setup btw. Use that money elsewhere, for a measurement mic for instance, it's tedious to integrate a subwoofer properly.
Thanks
Nice system, enjoy
Thanks
Set up will be -
Just curious, how are the B200's performing on those speakers? Nice set !
Set up will be -
No. Get x2 SVS subs instead.
Hi will 2 SVS subwoofer improve the music to worth it? Like it is better to get 2 SVS subs?
You will get zero improvement from an external Dac, once again the Wiim ultra is already excellent. It's better to get 2 subs, bass management is a complicated thing, having 2 subwoofers helps you achieve a more even response in the room. If you really have some money you can also buy a room correction (dsp) device like a minidsp device with a dirac licence for instance, that'll be even easier to manage the bass response.
One question, what have you already bought? What's your room size?
Thanks. Have not yet brought any of the set up yet.
So if I buy the minidsp device, will i connect the wim ultra streamer to the minidsp device?
Also which of the minidsp device do you recommend?
Sorry I'm new to audio systems
The 'subjectivists' simply can't fathom that an item this inexpensive can do so much and do it so well. It is a piece of kit that is truly a disruptive element in the hobby. :cool:
Or just that dacs are generally indistinguishable
What's your budget? And again, what's your room size? Cos if you havennt set up anything yet, people here will love giving you advice from the ground up. Lintons are great, topping b200x2 too, but really that's not what most people would choose here as a combo for that kind of money, there are better solutions imo.
Cos right now your budget seems to be around 3500-4500€, you can get some end game stuff with that kind of money.
