Miguelón
More or less the frequency part is the Nyquist theorm applied to acoustics, you should use sample rates twice the highest frequency you want to reconstruct. 96 kHz allows to encode 48 kHz.Would you please confirm the validity of the following argument. Thank you.
Sampling rates higher than 44.1 kHz are used to preserve audio in the band above 22.05 kHz. From the format of the audio file, it is then easy to infer what band the audio will be stored in a Hi-Res Audio recording, because accurate reconstruction of a continuous, frequency-limited signal from its samples is possible if the sample rate was higher than twice the highest harmonic component of the sampled signal. Then there is the bit depth, which defines the maximum usable dynamic range.
More or less because when you approach Nyquist limit, that’s it if you try to encode 99 Hz with 200 Hz sample rate you will find modulation sounds.
One can define a “passband”, in the case of 44.1 kHz is the frequencies between 20 kHz and 22 kHz that are not well encoded. It was suggested is a little bit narrow for filtering and avoid aliasing or imaging, and can be improved with 48 kHz files.
With some filters one can listen slight alterations on very high frequencies, especially young people I guess. I don’t really know so much about the relevance of 48 kHz on most people, the passband in this case is 20 to 24 kHz. I cannot hear the difference with filters neither.
As Anticollinet told, 24 bits also low quantization noise, but you’re right: in some action films for example it can get better peak SPL as explosions or other effects, increasing the disposable intensity range
