Hi-Fi System, How Much?
  • Thread starter Deleted member 28849
  • Start date
Status
Not open for further replies.
D
Guest
With many Reviews touting Budget systems with great sound, I have to object. At Retail prices, IMO a minimum of $15,000 USD would need to be spent in order to achieve Hi-Fi sound, not including Headphone systems in discussion. There are many factors in achieving Hi-Fi sound, I'm just talking money spent on equipment.
What do you think?
AdamG
Moderator
Reality
Your close. A lot has to do with the volume Cubic Feet of the room space you want to fill with music/sound. Then a big factor of considerable more to achieve Reference level SPL in the Low Frequency and Ultra low frequency. I spent over $8k on Subs alone. Trying to track all the bits, cable, DACs, amps, it gets boggling.
Other factors to consider. Is this a two channel music set up only or do you want to go for a surround sound movie as well. I have 15 separate speakers, 2 very large subs, 1 AVR and 2 separate multichannel amps. For a 9.2.6. System it gets costly fast. But you can bite off small bits at a time with expansion.
rdenney
If you can’t explain it, then why did you start a discussion on a forum that has only words for communication?
So let me ask this: Would equipment included the Stereophile A or B Recommended Components list qualify as “Hi-Fi”?
Rick “wondering who gets to define the hi-fi canon” Denney
Jimbob54
What do you think?
Come on. You've stated previously you're lonely, depressed, bored. This isn't a good way to get attention my friend.
D
Guest
Just 2-channel. At the Dealer's in a well constructed room 2 speakers can do the job.
D
Guest
Some people like to get "likes". You seem to prefer "ignores". Bye!
I get the impression Members like to jump on Audiophiles here. So I'm taking the snobbish audiophile approach. Sorry you don't like it, good bye.
Alexanderc
Florida, USA
A demonstrably transparent system (minus speakers) could be assembled for $3k or less and then you simply have to find the speakers that work best for you. You could put together something great for a smallish room for $5k or less retail (less if preowned or with discounts). My endgame system would cost about 65% of what you propose even if I had to do it from scratch. Of course I could spend more to get better looks or convenience features that don’t affect sound.
deprogrammed
Dayton Ohio
YAMAHA HS8 700.00
LOXJIE D30 182.00
PC Had for other reasons
JRiver 60
UmiK-1 75
Sooo 1017
Plus cables..call it 1117
D
Guest
I'm defining Hi-Fi as a Level of accurate 'live like' sound, not the equipment. If you think you can get that sound using budget equipment go for it, I don't believe budget equipment will get you there. You would need to spend money on an expensive piece of equipment somewhere in the audio chain to achieve Hi-fidelity sound.
Slayer
What do you think?
Well crap. My 2 channel rig (2.3 to be precise) only has about $8500 in it. Guess I'm stuck with a crappy midfi system as you call it. :facepalm:
D
Guest
:facepalm:
Status
