NTK,
I don't want you to get the wrong impression. I'm certain we generally agree on things.
It's just that your initial reply with the Toole quote at least
implied that imagination was doing all the work in, for example, my speaker choice decisions. (If that wasn't the implication, I'm not sure about the relevance of the quote and you could elaborate).
My point is: that's a bit rash.
Ok, then you will want to be of a scientific mindset I presume when making claims. That would mean being quite cautious about what you can, or have, demonstrated.
It's always possible sighted bias will influence any impressions of a speaker. But you can't really know in many instances and for an individual if that is in fact the explanation (unless you've done the scientific tests with that individual). In other words, someone thinking scientifically isn't going to overreach what they actually know or have demonstrated in their explanations. Is there some way, for instance, where you can know that I don't in fact
really like the actual sonic character of my Joseph speakers, and you know that it's all my imagination doing the work? Was there something inherently implausible in the claim, for instance from measurements (e.g. that I find the speakers to sound very clear and clean)?
Also; If for instance you are going to simply attribute what I take to be the "sound" of my speakers to sighted bias, do you think that knowing the measurements of your speakers somehow makes you escape the phenomenon of your sighted bias while listening?
Just like science gives me vastly superior information about what foods are good for me than my taste buds. But I don't leave my taste buds out when I pick what foods I am going to eat.
That makes sense, except it isn't really an analogy that addresses the issue.
I think the analogy I gave earlier is more apt: If we assume that the spices in a chili stew would tend to mask the difference in meat flavors and "quality of meat," then what sense would it make to care whether you have the world's "best" Kobe beef in there vs meat of "less quality," if the differences will simply be swamped by the chili spices? It wouldn't make sense, right?
Similarly as I've said...if we are going to follow through on implications...IF sighted bias was the overriding explanation for "why people hear what they think they hear" in speakers, and if we all listen in sighted conditions, why would it matter if you had speakers that "measure better" or not (or even pass blind tests more often)? If, under the conditions we'll actually listen to the speaker, we are just going to hear what we want or expect to hear...who cares, right? A speaker measures amazing, another really poor, but it doesn't really matter either way to sighted listening, right?
But I'm sure we agree that seems like a bit of an absurd conclusion.
Therefore, if you follow the logic back the other way, then to care about the quality of speaker (e.g. it's measurements) implies that we
can indeed discern such quality differences under SIGHTED conditions as well - the conditions under which we will be using our speakers.
So you can't be so fast to just ascribe someone's impressions of a speaker to imagination (as your use of the Toole quote implied), just because sighted bias effects are
possible. It's possible someone's impression of a speaker is almost entirely due to bias effects and "inaccurate," it's possible it's a
mix of bias and apprehending real sonic characteristics, it's possible that it's a
generally accurate impression of the sonics of the speaker.
Before implying or dismissing something as bias, it's best to have very solid grounds to do so. (Which is certainly possible - for instance, if you know the two cables compared by an audiophile measure the same, that certainly is good grounds for presuming reported sonic differences are bias effects, not apprehending real sonic characteristics).
Cheers.
