- Joined
- Nov 27, 2020
- Messages
- 736
- Likes
- 604
IMHO and in my context, the D10B is the perfect device and I use it for all of my USB-based input sources since it is (a) balanced output and (b) also a simultaneous digital bridge. That would be equally true for the D10S if my audio chain was based on consumer (-10 dBV) rather than professional (+4 dBU) nominal line voltages.What other dacs would be recommend for the A30pro. Btw i ordered the D10b after i sent the dx3 back. I am not getting enough volume with my smsl out of the A30pro. only if i use it with the L30 pre amp.
However, there are three very critical elements in my context that are different from most people's setup:
- I do not do any input switching at the DAC. Every audio source is routed to a separate channel on an analog or digital stereo mixer; and all channels are always active.
- I do not control audio volume on the DAC. Every DAC is set to pass audio at nominal gain (e.g., DAC mode rather than preamp mode); so I actively avoid all DACs with a volume knob.
- Room correction (EQ/ PEQ) is applied mid-audio chain, after the audio mixer and uniquely for each output device (e.g., headphones, desk speakers, room speakers); so I do not need any room correction capability on the DAC.
One other note: do keep in mind that the volume knob on the A30Pro can go all the way up to full volume and remain within its rated power. Many of us were trained to get very nervous of blowing out our speakers anytime we started to get close to "2 o'clock" on our amplifier's volume knob. That is not the case with the A30Pro.
