Hi,
Given my 4.15 long 4.5m wide 2.7m tall listening area, right side is mostly a heavy glass door to balcony but there is still room for a 45cm x 45cm corner absorber on the front-right corner and 30cm x3 0cm+ absorber on the rear right corner. Left is is completely open to dining area and kitchen (with nearest walls between 2m to 4m away from the 4.5m wide listening area).
To reduce rear wall reflections I moved the sofa about 80cm from rear wall (head ~1m from wall), tall sofa about 1m high 2.2m wide (3-seater).
What frequencies can I expect improved and by how much when placing a 45x45cm absorber in the front right corner? Just me sitting on the floor near the corner increased by 92Hz dip by 1-2db... Same for 30cm x 30cm (the width can be more than 3, depth limited to 30 due to glass door to balcony).
What can I expect by using something like a 2m x 2m x 40-50cm absorber on the rear wall? What is the optimal depth of that absorber considering the listening position is ~1m from the rear wall, to absorb reflections but also not sit too close to the reflections... Should I use a larger thickness below head level and thinner absorber above head level?
I also consider instead of using a cabinet for the receiver/streamer/router, to just place them under the TV on top of a 30-35cm tall 40-45cm deep absorber with a solid top. If I place 2nd subwoofer at rear rather than front (still need to measure and check), this absorber can go pretty wide (2m+).
Lastly, how useful is absorption behind speakers? If the back of the speaker is about 30-35cm from the wall, how thick and wide should it be? The speakers are about 2.5m away from each other and there is a 83" TV (~183-185cm wide) in between.
Note seems like my main dips, when placing speaker woofers 70cm from wall, are in the 90-120Hz area, with some problems 80-150Hz. Seems like my front right corner subwoofer is actually pretty smooth up to ~70Hz when placed in corner (maybe due to room being open on 2 sides and some of the walls are clay walls), and 2nd subwoofer seems to complement well for smooth response up to 80Hz if I place it next to the left speaker or next to the hallway at the left-back corner of the listening area/sofa.
The idea is to contact a local contractor to recommend on treatment and pass on the design to a contractor that actually builds everything, but I want to know I'm not being bullshitted and have an idea of what I actually need and also if prices will end up too high, which would be the first things to compromise. Also an advantage to any absorbers that will be easier to move and have highchance to be used when I move to a new apartment, as this is a rental.
Thanks!
Thanks!
