Hi,
New guy here and hoping for some instruction/advice. Hopefully, this is in the right place:
I’m trying to connect a MacBook Pro to a 5.1 surround system. Components are a 2023 MacBook Pro 13” M2, Denon AVVX1400-H receiver that I bought in 2017 and a CalDigit Thunderbolt 4 Pro dock that I bought from Apple yesterday. I tried connecting from the rear headphone jack on the dock to the optical input on the receiver using a Toslink to Mini Toslink digital optical S/PDIf audio cable. System settings seem correct in that it showed TS4 as the speaker output. However, no sound. Tried the same connecting directly to the Mac headphone jack. Same result. I also tried connecting via USC-C to HDMI cable. That worked for a few seconds and then the receiver turned itsself off.
So, a few questions:
1. Are there any system settings that I'm missing?
2. Why is the receiver turning off when using the USB-C to HDMI cable?
2. Do I need an external DAC? I know nothing about DACs but see this mentioned quite a bit when researching the subject.
Thanks in advance for any input!
