Biamping IS active. Unless you're running full range signals to both amps and still using passive crossovers, in which case you've thrown away any advantage of biamping as opposed to just using a bigger single amp.Are we talking biamping or active
That's what I was talking about. There's very little reason to biamp otherwise.Are we talking biamping or active?
What you are describing sounds like active-DSP operation.
Exactly - bi-amping with the passive crossover in place has no advantage.Biamping IS active. Unless you're running full range signals to both amps and still using passive crossovers, in which case you've thrown away any advantage of biamping as opposed to just using a bigger single amp.
We were talking different scenarios then.Biamping IS active. Unless you're running full range signals to both amps and still using passive crossovers, in which case you've thrown away any advantage of biamping as opposed to just using a bigger single amp.
What you're referring to is passive bi-amping, more a marketing invention than anything useful. Cheap is buying an extra power amp instead of a simply sufficient one in the first place?We were talking different scenarios then.
What you are describing is reffered to as Active speaker operation, which incidentally Meridian has been promoting for decades.
The biamping I was reffering to, was the other method.
Using an extra stereo poweramp and power each speaker (not drive) separately.
As I had explained before, this method is a simple, cheap upgrade add on method, by just buying one extra poweramp.
Ofcourse if you already have a capable, powerful amp, there is no point. But with mid-budget equipment, there is some benefit, not a lot, but there is.
My first post stated, that I thought those extra posts on the speakers were for that purpose, which made some sense, against biwiring which made none.
Perhaps you guys can just scroll back.
Google search on biamping:
The term Active was used, back in late 70s (to my knowledge ) to separate the mode of operation from Passive crossover. An Active xover circuitry was employed instead of Passive.What you're referring to is passive bi-amping, more a marketing invention than anything useful. Cheap is buying an extra power amp instead of a simply sufficient one in the first place?
To use the term "biamping" reffering to all Active speakers would have been nonsensical.
"Powered speaker" term, is used for those with internal amps, but with passive crossovers.This is correct. Active crossovers were pretty big in the 1970s for audiophiles with decent budgets. The major Japanese manufacturers has some wonderful active (line level for insertion into pre/power or tape loop) crossovers for use with multiple amplifiers (bi/tri amplified etc).
I don't think anyone would use the term that way.
Active loudspeakers are simply loudspeakers with built in amplifier/s. They may have active crossovers either in digital, analogue or even in some cases, passive internal crossovers.
Bi-amplifying loudspeakers with internal passive crossovers is also quite valid.
For what we think of as passive bi-amping, agreed. But for passive bi-amping the way these AVR manufacturers have defined it, the load part may be true, but you must have amps with the same power (or at least voltage) rating since the input signal to each amp is identical (full range of frequency and voltage). The "new" scheme confused the heck out of me (and got me into hot water in some forum debates) until I understood what they were doing. It is basically an easy way to make customers feel good by connecting the "unused" amplifier channels in a multichannel AVR to the speaker, even though the extra channels have the same voltage requirements as the original single channels.Bi-amping with passive crossovers intact (bi/tri wired at the terminals with the shorting bars removed) generally will mean each amplifier will see an easier load than it would driving the entire speaker system. Not only that, amplifiers can be chosen for their strengths- say an ultra quiet (low residual noise) /medium power amplifier for mid/highs, particularly with horns and a powerful amplifier for the low/mids. Levels can also be more easily tweaked as well.
Correct on every point.Bi-amping with passive crossovers intact (bi/tri wired at the terminals with the shorting bars removed) generally will mean each amplifier will see an easier load than it would driving the entire speaker system. Also by keeping the passive crossovers, mid/high drivers are protected against DC events and the attenuation provided by those networks reduces residual noise as opposed to active designs with the crossovers being done prior to amplification.
Bi-wiring on the other hand (simply paralleling speaker cables to the 'separate' speaker terminals) is just a complete waste of time.
Yes, that's where there's an actual benefit. It's what I did for my NHT 3.3 mod, pulled a bunch of components out of the passive crossovers (all of them for the woofer), put in a time delay and EQ, and actually got deeper bass, higher SPL, and better integration between top and bottom.Are we talking biamping or active?
First domestic Active speaker was Meridian M1, with active xover and dedicated triple amps in 1977!
Well . . . .Pretty sure the Philips MFBs (domestic and studio) beat them to the punch from the early 1970s:
Philips RH 545 Studio | Inner Magazines
The RH 545 Studio was Philips’ most advanced MFB loudspeakers monitoring its own playback through a feedback loop.www.inner-magazines.com
I think we got our terminology mixed up.Yes, that's where there's an actual benefit. It's what I did for my NHT 3.3 mod, pulled a bunch of components out of the passive crossovers (all of them for the woofer), put in a time delay and EQ, and actually got deeper bass, higher SPL, and better integration between top and bottom.
Of course, the various active speakers around my house (Vanatoo T0, T1+, and Kali LP-6) all run separate amps for tweeter and woofer, so take advantage of the extra electronics.
Well . . . .
That's a servo speaker.
There is no xover circuit of any type.
I think you are mainly referring to power capability.But with mid-budget equipment, there is some benefit, not a lot, but there is.
