The first-order at 7293 Hz is to manage the downward slope of the DXT above 6kHz. It has 6 dB/octave slope, screen captured Seas' spec and superimposed 6 dB/oct on top of it.Hi All. I've built a pair of Heissmann DXT-Mon-182, and I built the analog crossovers. They measure very well. But I also want to use my MiniDSP Flex-8 to try a DSP crossover.
Here's the problem. On Heissmann's site, he specifies the crossover as 1950hz LR 4th order. But he sent me the attached parameters for DSP, and I can't make heads or tails of the 1st and 2d order crossover notations. On the Flex-8, I can only input one high- or low-pass per driver. How do I use Heissmann's 1st and 2d order figures?
FYI, I have already input a LR4th at 1950hz, and I used the DSP parameters on the attached. For the drivers being used, the 1950hz figure falls right where it should per the mfr. spec sheets, and higher or lower tends to increase distortion for one or the other driver. My initial settings got a very good measured result except that the overall tweeter level measured a bit high when I did a near field measurement (and it sounded a bit hot, too).
I hacked together the tweeter's response and the 1st order filter, it's easier to see how it removes the large hump due to the waveguide and combines with the acoustic roll-off of the tweeter to make a 12 dB/oct high-pass, at least for part of the response:
Putting the tweeter together with all of the filters:
It looks like a very competent crossover. It addresses the falling response of the tweeter at high frequency, and results in a nice 24 dB/oct acoustic slope.
If you were to do active, it might be a good idea to keep the capacitor for the 6 dB/oct filter. It will be protection against DC and other accidents and events
The mismatch below 1.8 kHz is due to the changing impedance of the driver interacting with the 3 uF capacitor. Retaining the L-pad in your passive crossover (R6 and R7) will further linearize the impedance and the active and passive responses will match even closer. It will decrease any hiss further.
I hope this helps with the tweeter section.
