Hi, beginner here. Would love some help interpreting REW data.
The listening part of my room is: 380cm (150inch) (front to back) cm x 350cm (138inch) (side to open floor plan, towards my back when pic was taken). Gear: pc>minidsp flex> svs pb2000 XO 80Hz BW24/dB and Apollon ET7040>Dali Opticon 6 XO 80Hz BW24/dB. After some unsuccessful tries aligning the mains with the sub via the Alignment Tool, I did it this way by ear:
All the measurements are taken from MLP (I push the couch against the back wall and set the tripod on the ground with the Umik 1 pointing at the stereo, also using the 0 degrees calibration file). Dirac, when on, has the curtain set at 250Hz.
Questions:
- Why is the 'sub only' measurement so low in SPL? I only change the frequency range to 20-200, and mute the left speaker (right speaker gives the dither)
- Does the 10.5 ms delay look alright compared to no delay? To my ears, the bass sounds more tight and coherent. I don't understand the phase readings yet, and I feel ChatGPT is bsing me.
I hope I made the correct measurements, but here to learn, so feedback is much appreciated. Thanks!
Questions:
