4D_Coaxial_Cube
- Joined
- Apr 28, 2021
- Messages
- 112
- Likes
- 40
So I got a Minidsp SHD Studio because the SHD was twice as much. Deer Creek Audio's Rbay acct had the Studio variant for 1500USD a couple of weeks ago, then I checked again the next day and saw they reduced them to 950USD plus tax and 40 bux shipping. The user manual shows a routing configuration menu in the app that isnt present in the console when I use it. I asked Perplexity.AI which is a decent model with a more science focus rather than engagement oriented, but I am unsure if the console was updated or if something is buggy on my end. It said there is a known issue with the input routing matrix not appearing due to a few reasons. I went through all the suggestions to make it appear a few times and havent seen the routing matrix from the manual one time. I am able to assign Dirac 1 or 2 to each output channel, but thats it. So here are the things I am trying to connect.
I have an AES 110ohm Canare balanced cable going to an R2R Holo Audio DAC carrying signal from channel 1 and 2. Then I have 2 SMSL SU1 DACs using Canare SPDIF cables and 4 x E15HP2 Rythmik subwoofers, with 2 stacked in each corner of the front wall. The 3rd output in console controls 2 of them, but without being able to set the routing better.. the other 2 are controlled by an output that is controlled by output 1. Clicking Dirac 1 or 2 on the 4th output doesnt do anything to any speakers/subs.
Im not sure how to fix the issue. Ive tried several configurations and reloading the drivers/console software and a lot of suggested fixes, but I have not seen the "input button" that is supposedly at the top of each output strip even one time. Ive started to think that the console no longer uses them. Any help would be appreciated.
I switched out the 2 SU1 dacs with a Gustard R26 and am able to assign high and los pass slopes to each output but really would rather sell it as I think it is overkill for this duty. Im open to DAC suggestions that have great measured performance with AES input and balanced output... features dont matter of course and I would rather the bang for the buck go toward measured performance over unneeded connections etc. Thanks.
