Chris A
Here goes.
1) I'd first think about moving the measurement microphone to be 1m in front of the front baffle of your loudspeakers, then place a good amount of temporary absorptive material over the floor between the microphone and the loudspeaker under measurement, as well as temporarily covering anything that's acoustically reflective between the loudspeakers and on any nearby sidewalls within 4-5 feet of the loudspeakers. I'd center the microphone on the tweeter's axis. Group delay and excess group delay:
2) I also recommend adding both absorption and diffusion to your room. You have a local rise in RT values above 1700 Hz and your average RT values are in the 350-450 ms range, which is a little high for a smaller listening room. You have acoustic reflectors at 8.2', 19', and 21.4' (path length) from the right loudspeaker that significantly affect the phase and group delay measurements. In fact, below 2kHz, the group delay curve is noisy (no areas where the GD curve is flat and smooth, even using psychoacoustic smoothing). Try the closer microphone measurement position on-axis with absorption on the floor and covering anything in the nearfield of the loudspeakers (especially between the loudspeakers). I don't know your room dimensions, but it looks like it could be in the 2K-3K cubic foot category:
3) It looks like your subs may not be very well time aligned to your left/right loudspeakers, but the measurements are noisy enough to mask exactly what the sub lag time(s) might be. You might think about pairing your left or right loudspeaker with each sub (1 and then 2), taking measurements with just one loudspeaker and one sub (the sub closest to the loudspeaker). The spectrogram view is fairly noisy and doesn't attenuate very quickly, even after 100 ms...
Chris
