Help to choose my new amplifier
Redwine
I am really in doubt, need new amp to run my Snell c/v, and have located two options:
1) Purifi Eigentakt 1ET6525SA Stereo​
2) Hypex NCx252MP Stereo​
The Hypex is nearly half price, so do need good arguments here!
Can you help?
From which manufacturer?
Or do you mean the modules compared as such between each other?
Same manufacture, but yes the two modules up against my need, taking into consideration the heavy price difference.
Which manufacturer?
From a well-reputed manufacturer, who is knowledgeable and can put together amplifiers in a good way, then, with your speakers you will not hear any difference. Both modules have power so it is enough for your speakers plus SINAD below the limit of audibility.:)
Which manufacturer?
Will even the Hypex have sufficient headroom, when playing in a 60m2 room?
Per measurements from Stereophile, the Snell has a sensitivity of 87 dB/W/m, and it is not a difficult load. The Purifi module will give 2.6 dB higher output power into 4 Ω (and 1 dB into 8 Ω), but either should be fully adequate to drive the Snell.
The "recommend" amplifier power for the Snell is 50-250 W, and both amplifier modules have rated outputs near the higher end of the recommendations.
If you don't intend to push the speakers and your ears to the breaking point in combination with a very long listening distance (in a room where the sound is significantly attenuated) to the speakers, plus also listen to extremely high dynamic music then I agree with NTK above. :)
But if that extreme scenario were to be the case, you should also consider speakers with even more power handling. Note that we are then approaching PA speaker power performance range.
  • What level do you want?
  • How far are the speakers from the listening position?
  • What power amplifier did you have before?
Speaking of amp power. Page 34, #662.
With 120 amp watts and 91 dB sensitive speakers. Maybe a little overdriven by Audio Pro, say 88-89 dB sensitive. Then with this song:
It works but it wouldn't hurt to have even more power. In and of itself I don't want to annoy the neighbors anymore so it's good as it is now.
BUT the same 88-89 dB sensitive speakers and sausage-pressed loudness affected recorded pop music so well maybe 10-15 watts would have been enough.
So it depends on what kind of music you play, plus of course how high the volume is.:)
Edit:
We may not have mentioned in the thread that bass requires much more power than treble. A pair of tweeters can be powered up by a 20 watt amp and that may be enough. A subwoofer, in extreme cases a small sealed subwoofer box, ....well feed it with hundreds, say 400 RMS watts and maybe even that won't be enough (I have experience with that). :oops:
Both will sound the same. Very few speakers will be able to set them apart. If you have the budget for Purifi go for it. FOMO is real and you will be itching wondering what do you miss out.
I know that purifi will sound the same as my AVR, with my speakers. I don't feel that way.
Nitpicky point: low dynamic music is usually the worse load. The more compressed to death it is, especially the bass, the more it approaches torture test signals. Trust me, I'm an expert... :D
A rumbling same level throughout the entire frequency range sound porridge. Sounds do it undeniably, if it's good sound, good aporoatch to record music is another question. :)
In any case, the need for that type of loud music has more or less disappeared now in connection with the reduction of FM radio channels....or?
On the other hand, the artists, the record companies may still want it to sound loud when the music is streamed so that would contradict that?
It's an interesting topic though.:)
Oh, the loudness war is far from over - or it is, and we lost it. Steaming has the exact same problem as radio did: you'll wanna stick out with your production, and loudness is the easy way.
Unfortunately, I think you nailed it here, FOMO‍
Vintage amps. Better than modern ones? Probably not. On par with , maybe , sometimes. But 48 pages, 957 posts. How come? Nostalgia? Buy something now that you couldn't afford as a youth? Is it the vintage looks? In short, the feeling of.
You have been looking for an amplifier for more than 8 months — what is the problem?
