Help Shape Fosi Audio’s First Streamer — We Value Your Input
@Fosi Audio
USB out requirement for me
Use 4Stream for streaming software and App
We know that 4Stream is a great place to start as WiiM took it and evolved it but just plain 4Stream would be fine
Let's talk Digital Volume DISPLAY:
Verifying the current sound level prior to hitting play is very important to me. I have a prefered starting level for TV, a bit higher for Movies, and a variety of preference for Music depending on the material. Also, It's impressive when you know the precise level for a certain track that you want to demo/show off for guests so that the opening notes/vocals present themselves as intended.
And finally, If my kids are watching cartoons and i yell turn it down i don't want to go back & forth on what is enough. Just say turn it down to 33 and they comply.
@Fosi Audio
dual subwoofer outputs
room correction
HDMI input with dolby digital decoding and downsampling to 2.1 integration with a TV
I could understand -from the business aspect- adding a streaming device to your catalog in addition to your newly released ZP3 [RCA+XLR] preAmp.
I will hold out :(, until FOSI asks me to 'help shape' a balanced ADC, which also happens to feature built-in digital I/O + streaming.
Oh yes, and under $350.
If anyone can do it, FOSI already has all the building blocks and the know-how.:)
Like Wiim mini with XLR outputs, no DAC and bigger screen than Wiim product 3.5 , maybe you can take the screen out a cheap tablet pc. Price around 200.00
a proper streamer should have enough digital outputs to support most DAC inputs. IE coax, toslink and USB. Also the ability to choose between airPlay 1 and airPlay 2.
I filled it out, nice to see a company that values user input. IMO hifi buyers are mainly buying streamers because they don't trust integrated streaming solutions to be supported for the life of the product - see . So, software stability and reliability are #1.
Just to note that Harman did issue an update for this device and the Arcam SA30 (identical inside) a few moths ago that enables Tidal Hi-Res - the original commentator on Reddit rather belatedly acknowledged that at the bottom of the thread.
LMS works quite well with 60000 tracks . It depends on what it runs on . I tried one of the older raspberry pi that I own that did not work .
No problems on my intel NUC . Or in the past on windows or linux I’ve had all kinds of mini servers in the past .
Now I have Roon on the NUC and a new pi for LMS .
Roon really wastes cpu cycles it must be incredibly inefficient compared to LMS
i've just installed Lyrion Server on a dedicated Pi4 4GB . it works, but the server gets stuck (for me) too many times trying to index folder names in Hebrew (plus 100% CPU load). since I have 100s of those, i guess it's not a good solution for me. other then that - the WiiM / Lyrion integration is extremely good
*my Navidrome sever doesn't have this issue, and index everything (61k songs) extremely fast
