- Thread Starter
- #81
Re the soundstage.You're most welcome.
FYI for the culture here "resolving" is not an objective quality. However,
> better separation
is objectively verifiable.
> 2325 is warmer and sounds thicker
This indicates flaws for an amp, supposed to deliver "straight wire with gain"
IOW distortions your ears just happen to be accustomed to, or actually enjoy enough that it might be worth pursuing as an effect, e.g. tubes* or DSP in the line level stage
> I might have heard stuff not noticed in the past
likely from much greater fidelity, aka accuracy / transparency
> wider soundstage
This on the other hand may not be measurable objectively, but IMO still exists as a goal to be pursued, to taste.
* Schiit Buf is an inexpensive way to play with adding such desired distortion. The included tube does not do much, but there's a whole world of others to test.
So long as you can always return to transparency with your core signal chain, don't let others tell you such experimenting is heretical, the final judge is you, your unique ears & brain psychoacoustics ultimately your taste and enjoyment.
Of all the 'observables', to me this was the easiest to detect. I'm used to my room, and how certain tracks sound.
My speakers are very widely spaced, maybe 6 yards apart, and the soundstage ran from one to the other.
With the new setup, the soundstage actually seem to extend wider then the width of the speakers, which seems physically impossible to me, but also pretty cool.
