Help selecting a secondary stereo amp
I'm thinking about a couple of 3e a7 monos, $170 each with powersupples on Amazon seems hard to beat, ....
It’s a good amp—you got a thumbs-up for that,:) but not for:
...., and the op amps appear easy to swap out if I need to refine the tone.
Don't fall into the rather pointless op-amp swapping trap. You're better off spending your hi-fi time on things that yield real, audible results—not imagined ones.
Regarding diy speakers:
To me, this seems a bit gimmicky?
Comparing similar drivers,.cabinets etc, surely factory assembled would be more precise due to better assembly conditions?
Don't judge a book by its cover. That Mechano23 speaker might look a bit homemade—which they are—but check out Amir’s measurements and you’ll see they’re the real deal.:)
DIY speakers can run the gamut—from abysmal to state-of-the-art. They range from amateurish, slapped-together boxes to... well, state-of-the-art craftsmanship and finish.
Can you build better DIY speakers (including subwoofers) for the same price as commercial ones? Certainly.
Could the reverse be true—a better commercial speaker than a DIY one? Absolutely.
But DIY speakers aren't a gimmick. They are what they are.:)
Re: op amp rolling. . Solid point. Also,.my dac has a number of filter coloration settings I could expirement with when trying to compliment speakers.
The issue I see with diy speakers is that speaker sound is massively variable, and is reliant on upstream signal factors as well as room/treatment, and my ears.
If I brought decent speakers from amazon or somewhere I can return, I can expirement. If I build something and don't like it, I'm stuck with it, and have to try and mod everything else to find improvements.
You have a point there.:)
However, for DIY designs that have undergone extensive measurements, you can more or less tell how they will sound based on those results.
If you plan to build DIY speakers from scratch—aiming for something truly excellent, or even state-of-the-art—you should probably prepare for extensive theoretical calculations, a number of iterations/test enclosures, measurements, further theoretical calculations, and so on.
Alternatively, you could copy an existing high-quality design or use a good DIY kit.
It depends on what you want to do and whether you find the process fun and rewarding.:)
You can take a look here at the amount of work that went into these excellent DIY speakers:
Edit:
Except for the subwoofer. With a good bass driver (high X-max and high power handling) and plenty of amplifier power, you can achieve great results. Slapping together a sealed subwoofer out of plywood isn't difficult.
Take a look at this; the hard part here is the superb woodwork, but aside from that, the enclosure itself is sealed:
But DIY speakers—mostly because there’s a sense of satisfaction in building something yourself. It’s fun to learn in the process, too. Even if you’re "fooling" yourself, maybe the IKEA effect makes them sound really good?
Like op amps, DAC filters make little audible difference unless you choose a very slow, non compliant (with sampling theorem) one. But then all you are doing is letting ultrasonic images fold back into the audible band and cause distortion / and/or rolling off the frequency response.
If you want to tweak the sound to taste, use tone controls or equalisation - that is what they are for.
Thanks for the early responses!
Just to clarify, I don't need anything with a dac, streamer, or even a phonostage. I have all those in separates, which Id connect to the amp.
So, I suppose a requirement would be fairly typical inputs: balanced xlr and rca. No need for digital inputs as I have a nice dac (with xlr+rca out) already. Something transparent, maybe boarding on warm, but not tube-like.
Just a nice robust AB amp that does one thing well.
If you still like Marantz and want class AB, why not look for a Marantz MM7025? It has balanced and unbalanced inputs, outputs 140W per channel, is of good quality and SH I think you can find it for $500.
DIY audio and DIY speakers in particular are just sub-niche parts of the hobby, really a matter of taste, whatever floats your boat choose your own rabbit holes...
The A7 will serve you well for what they do, if you find you might want that bit more oomph, look out for 10A versions of the 48V PSU.
With Mono variant you could go adjustable to go to 51V when turning them "up to 11" and get greater longevity at 35-40V otherwise
but most consider such a rabbit hole, and added costs unnecessary
All well-measuring/transparent modern solid-state amps sound the same. It is quite possible for a solid state amp to have audible distortion or rolling off frequency response, if faulty or of poor design. A 50 y/o vintage amp can also have drifted out of spec compared to new condition.
I would not expect though - any variation to be a night and day difference unless there is something seriously wrong.
(50 yr old aint modern) I agree with what you say though. Of course they have to be functioning correctly. Thats kind of a given
I may have missed some details in this thread, and maybe someone already suggested this. But if the OP wants a $500 AB integrated amp it seems like Yamaha is the most obvious solution.
This the thread has been gold for information.
I'm waiting on a couple of 3e a7 monos. All up, both cost about $180 with 5A ps's due to having some Amazon prime points available. Should be plenty for my 100w 4 ohm suspended 3-ways.
I'm looking forward to comparing with my "golden age" receiver, and prepared to be pleased, and disappointed.
That said, the primary reason for getting these was an amp I can leave playing all day, mainly powering streaming and CD signal.
I'll reserve the 2325 for phono so I can blame my stylus if fidelity is pointing the finger either way.
Is there a break in time with class d? Do the caps have to heat form?
On that; since this is a science grounded forum, can someone explain the theory behind cable break in ?
Exciting. Let us know what you think of them once you’ve hooked them up.:)
Break-in, or burn-in.Don't do it. It smells so bad.
The theory belongs to the realm of psychology—specifically, the "imaginary sound improvement" phenomenon.
A pair of A7 monos is an excellent choice.
There is no break-in here or cable burn-in. Often these words describe audiofoolery. Moving material can have a work-in period, like speakers. But the effect is far less important than the stories suggest IMO.
The amp comes with TI 1612 opamp. No need to change anything, it can basically not get better, but worse. As described in the comprehensive measurement threads. To my knowledge the only plus these expensive opamps could possibly declare for themselves is heat management of the unit itself. And it's a very slim chance that is actually needed.
A theory that is wrong? I can do that.
The "theory", such as it is, seems to be grounded in something real, but applied badly. Do mechanical bearings break in? Yes. So does everything else with moving parts. Smother motion.
Electrons "move" in the cable. They vibrate at least. So CLEARLY they will move more smoothy as they "break in" the copper with their motion and the signal gets "smoother".
I'll say that drivers straight from the box, from experience, I expect it to take 15 minutes at most for them to sound like I expect. Bass drivers sound deeper, tweeters sound highere. IIRC, tubes have some issue early on and need to settle a bit. Solid state? Other than that? All claims I have seen about break in and burn in fall directly in the "psychology explains it" realm.
..tubes have some issue early on and need to settle a bit. ....
When it comes to tubes, there appear to be a few things in that world that can be considered—to a greater rather than lesser extent—snake oil. The video below covers new vs. old tubes, tube burn-in (except for the first few seconds—or tenths of a second? ...maybe... or maybe not?), cryo-treatment, and tube dampers:
That should work well.
I just noticed or 'remembered' this newish, monoblock option from 3e Audio - it does NOT INCLUDE a power supply unit.
XLR/TRS or RCA input is selected by a sliding switch on the back panel.
I currently see a coupon for 23 percent off $129.99 or about $100 for the BLACK colorway. Perhaps this is a targeted listing.
To date, I am not aware of an independent measurement of this amp.
Yes, we are waiting for tests & reviews.
Since 3e has not shown up personally to tout this "giant leap" new Gaan tech, I suspect their measurements will not come close to their mainstream achievements with A5/A7.
Of course some need Moar Power more than maybe inaudible levels of SINAD, no one can say yet "how they sound"
But I trust 3e and bet they'll be at least "good enough" likely better
We just have to wait and see
Just an update. My 3e a7 monos arrived, and working flawlessly
I remembered to disable volume, and switch my dac into preamp mode. No poping, clicks etc.
The auto power on/off is a nice feature, no trigger required.
Ok, sound:
Caveat: both amps are powering my AR11 45 yo speakers and my genX ears, so the ceiling might be lowered some.
The a7's MIGHT be a little more resolving then my 50 yo receiver, but it's hard to be sure. The 2325 is warmer and sounds thicker.
However the a7's have a wider soundstage and better separation, and I think I might have heard stuff not noticed in the past.
I'm very pleased with the a7's, look good, sound great, and do exactly what I need them to do.
Thanks to everyone for the comments/advice that got me to my purchase decision!
Ok, sound:
Not sure how you compared, but resolving? Better soundstage and separation? How does that work with an amp?
You're most welcome.
FYI for the culture here "resolving" is not an objective quality. However,
> better separation
is objectively verifiable.
This indicates flaws for an amp, supposed to deliver "straight wire with gain"
IOW distortions your ears just happen to be accustomed to, or actually enjoy enough that it might be worth pursuing as an effect, e.g. tubes* or DSP in the line level stage
likely from much greater fidelity, aka accuracy / transparency
> wider soundstage
This on the other hand may not be measurable objectively, but IMO still exists as a goal to be pursued, to taste.
* Schiit Buf is an inexpensive way to play with adding such desired distortion. The included tube does not do much, but there's a whole world of others to test.
So long as you can always return to transparency with your core signal chain, don't let others tell you such experimenting is heretical, the final judge is you, your unique ears & brain psychoacoustics ultimately your taste and enjoyment.
Okay, was it verified objectively? Crosstalk is rarely an issue.
Absolutely it was verified objectively.
I was sitting in my fav chair, eating a sandwich and had a grin on my face. Good enough.
