- Thread Starter
- #41
So, if you sell your Marantz 2325, it looks like you could get around $2,500- $3,000
for it.Your budget is $500. Wouldn't you want to increase that budget a little to gain more flexibility and a wider range of choices?
HifiShark — Used Hifi Price Search Engine
Used Marantz 2325 for sale on 400+ second hand hifi sites & shops. Use Hifi Shark to monitor pricing and global availabilitywww.hifishark.com
Is having your Marantz 2325 inspected, serviced, and having parts replaced as a preventive measure not an option?
By the way, your AR11 speakers..
....are getting close to sixty years old. If you decide to sell your Marantz 2325 and put that money into hi-fi, you might want to consider a new set of speakers—and an amplifier. In that case, spend the bulk of the money on the speakers. That said, the AR11s might be excellent vintage speakers; they seem to sell for around $450 on Hifishark, so they are clearly still sought-after. Anyway, just a suggestion.![]()
I'd rather sell my child.
The 2325 sounds fantastic. I recapped it a few years back, and it keeps beautifully in spec. The AR11's really match it, and given they are almost impossible to find, I'd probably only sell them if I could find a pair of well-priced AR LST's or AR-9's. With vintage this old, you want to listen to it, and you want to preserve it. Heat damages, but I enjoy listening all day, thus the secondary system.
I lucked into a decent, recient DAC, so that, the amp, CD transport and streamer all fit pretty well together. I'll look for a set of modern speakers at some point to really separate my digital based system from my analogue. It would be fun (and maybe distressing) to compare the same music across 50+ years of tech.
