Help! PlayStation 5 audio setup issues.
edoardo
Hi everyone, I need some help with the PS5 audio options. I have two active monitors (Adam t5v, XLR and RCA inputs) and I would like the ps5 audio to go out there to watch movies etc. I heard that I can use USB DACs but I am not an expert on the subject ... can someone explain to me what I need to buy to complete my audio setup and connect the ps5 to the speakers? I have a scarlett 4i4 for my pc but since it doesn't have the optical input I can't connect it to the ps5 with the usual Astro HDMI audio splitter. Thanks! Help! Audio setup issues.
Music1969
Does this help (i only did a quick google...)
https://blog.jdslabs.com/2020/11/connecting-a-usb-dac-to-ps4-or-ps5/
E
edoardo
those are for headphones, i want a dac that i can simply connect to the speakers through RCA
abdo123
Brussels, Belgium
if i remember correctly, you need a USB DAC with the UAC1, not UAC2.
but that is for the PS4, not sure if same thing goes for the PS5.
does your TV not have optical or headphone out?
E
edoardo
I only have a monitor so no optical at all, i was wondering if the Rode Ai-1 will work? it has jack outputs.
Racheski
Chicago
abdo123
Brussels, Belgium
check online for DACs that people have actually used so you're sure that they will work. there are very few UAC1 DACs out there in 2021.
E
edoardo
I Just figured out that my monitor has an 3.5mm aux for headphones. Can i use something like this and connect my monitor to the speakers?
Pancreas
problem with this is the sound will be downgraded
the only way to get good sound, would be to get
audio extractor with optical
audio interface with optical
this will allow you to get a 5.1 surround
so you connect your speakers to the audio interface via TRS/XLR
connect the ps5 to the audio extractor via HDMI, then audio extractor to monitor via HDMI
and audio extractor to audio interface via optical cable
