Defi
- Joined
- Jan 15, 2025
- Messages
- 107
- Likes
- 168
Greetings everyone.
I spent a while today moving my speakers and subs around taking measurements. I used REW room simulator to pick a few good spots and then moved them around between those, and measured 10 spots in total. I have landed on the following 3 positions for the mains that I think turned out the best. Unfortunately I ran out of time to start moving the seating position around, but that would be my next task. Please let me know if there is any obvious choice from here. I kind of let my curiosity wander and position 1 (blue here) is in front of a door that I only need to access once in a blue moon, but it would mean moving the speaker (some tape on the floor to mark the position is probably sufficient). I just posted a picture up to 1kHz for quick reference (with var smoothing I think).
Ok why is it not letting me attach the .mdat. Please stand by. Edit: I can't figure out why it's greyed out when I try to attach it. txt in the meantime?
Some anecdotal notes for what it's worth: Pos1 is nearly up against the side walls and ends up being the closest to an equilateral triangle. The only problem I had with in in listening was that the phantom center was incredibly sensitive to being in the sweet spot, like the order of head-width, but when you're there it has quite a nice soundstage. The center doesn't disappear but it skews asymetrically in the direction you move (i.e. if I move my head a foot to the left the center seems to go 2 or 3 feet to the left). This placement is a lot of fun because there is so much room between the speakers you kind of forget they are there.
Pos3 is results in a narrower soundstage but a much broader sweet spot. I haven't spent much time actually listening at Pos2 yet.
Edit: Ok after the 1 millionth edit I've unstupified my caffeine riddled brain and attached something that I hope is useful. Please let me know if I can be more useful.
