Hello All,
I am trying a couple of locations for my subwoofers that give me the best overall output. They are located on my front wall and flank my center speaker. After a lot of measurements, I have found the two best locations but I cannot decide which is best.
This is the combined response of both subs, at the locations that have the flattest response. Yes I know that neither are particularly flat. This is no smoothing or EQ or anything. I have a Denon 3600 and plan to EQ with MultEQ-X, but I need to try and get something it can work with easily from the start, so that it isn't trying to boost nulls etc.
I would be crossing over to the mains around 80hz. The black trace gives more output at 70-100hz but falls off very jagged. The orange trace doesn't seem as good, but has a much smoother rolloff at the upper end.
If you had to pick between these, which would you recommend? Is one any better than the other? With EQ would they practically be the same?
Edit- the 65hz dip is due to a room mode that I can't fix without different placement or more subs- neither are in the cards.
Sorry for all the questions- just wanting to learn!
