csepulv
I am piecing together a new family room (repurposing old room) and I am using the opportunity to improve my music listening experience. The room is mixed use: home theater, music listening and home office.
I've spent countless hours reading posts on ASR. While the information is incredible, there is a lot of it now swirling in my head. As I consider my room, my graphs and my goals, I am a little confused as how to proceed. In my ignorance, I might be missing measurements that are obvious to others or I might be making the wrong conclusions. I realize I will be asking questions that have been already discussed numerous times before. But, as noted, I struggle to apply my tidbits of knowledge to my situation.
Equipment
-Denon 3808ci AVR
-Raspberry PI w/ Volumio => miniDSP DDRC-24, with Dirac Live applied (for music listening)
-Paradigm Premier 800f (towers)
-single Paradigm Cinema sub (from older setup) crossover at 80hz
The miniDSP outputs to analog inputs on the AVR, playing in pure / passthrough.
I placed the sub based on moving the sub and take measurements, looking for flatest curve and minimal nulls
Room
My room is oddly shaped.
I am open to either orientation, if one is obviously better (graphs below)
The room is fully carpeted and there is a sectional sofa, as noted. (A desk and some back wall bookshelves are in the room as well, though only noted in the diagram). The side right wall (in diagram) is mostly large windows - 20', 18" from floor to about 20" from ceiling. 9ft ceilings.
Measurements
Long Wall Configuration
Sweep (1/6 smoothing)
MMM/RTA (no smoothing)
Side Wall configuration
Waterfalls
Main Questions
-is one room orientation better than another? Why?
-Should I get a different subwoofer? Second Subwoofer? Which would you prioritize?
-how effective might room treatments be?
-should I be patient?
Overall, I am happy with the sound, but I am comparing it to previous setup of Paradigm Cinema 5.1, with whatever room correction my dated Denon AVR Audyssey provided. So I am am not sure how much more I could be squeezing out of my system. I am willing to invest in new subs and other items, but I don't want to rush into anything.
When it comes to room treatments, I might be able to do some bass traps in some corners, but as the room is shared use, I can't put much treatment on the wall, particularly if they are deeper than 2-3".
Once I settle on room orientation, we will be adding some bookshelves.
Any suggestions? Other measurements I should make?
I appreciate any advice and especially appreciate the thought process behind such advice.
Equipment
-Denon 3808ci AVR
Room
Measurements
Waterfalls
Main Questions
