I need some help. Below is a REW measurement and as you can see below there’s a big dip 90 – 180 Hz and another around 300 – 450 Hz. These change depending on how far away from the front wall I place the speakers. Which leads me to believe it’s room reflection related.
According to the Wall Bounce calculator 2D Excel file (http://arqen.com/wp-content/media/Wall_Bounce_Calculator_2D.xls) it should work to put absorbers on the front wall. I have never done this before so I need all the help I can get?
What size & thickness should I get?
Will front wall treatment be enough?
Should I get the fabric absorbers or the ones with wood patterns on the front?
Anything else I can do to improve the sound?
My equipment is…
Ascend Sierra LX speakers
Two Aperion Audio Bravus II 8D subwoofers
MiniDSP SHD
Audiophonics Hypex NC502 amplifier
The room is 12’4” x 24’7”. The audio stand contains a TV lift and has a skin of acoustic paneling. I liked the look and thought it might help acoustically. The screen shot below shows the location of the speakers and the subs. There is a 4’ opening to the right (where the 7.48 measurement is listed in the pic below).
Any tips will be greatly appreciated. Thank you.
My equipment is…
MiniDSP SHD
