Good day,
I’m looking at buying the Subtonic Storm iems, which seem to need a lot of power to drive – sensitivity 103dB@Vrms, impedance 6.1 Ohm. I calculated that as needing 2.6 watts (!) for 115 dB loudness peaks.
If the calculation is correct, could you please help me identify a DAC/amp combo that would drive those iems to that level?
Thanks very much in advance!
(PS if understand correctly, the forum’s position is that you shouldn’t be buying expensive iems at all – but I would appreciate it if you could help me find a source without making this into a discussion about the wisdom of buying expensive iems).
