itchaboyagain
- Joined
- Sep 3, 2024
- Messages
- 9
- Likes
- 7
Hi everyone,
I'm working on a project to detect and document high-pitched whining sounds from LED light bulbs. These noises are subtle, and I want to ensure that I capture them accurately if/when they’re there.
Audio science is not my area of expertise so I was hoping some of you kind folk could help set me on the right path!
Here are some key details:
Goal: Detect and analyze faint high-frequency noise (potentially in the range of 15kHz to 20kHz) emitted by some LED light bulbs.
Requirements: Low self-noise microphone with flat frequency response.
Budget: I'm open to spending more if it means higher accuracy, but I'd prefer to keep costs reasonable.
I've been considering options like the Earthworks M23 or MiniDSP UMIK-1. I’d also love some advice on spectral analysis software that would allow be to export graphs of any readings I take. I’ve dabbled a bit into this world and BOY am I overwhelmed. I basically just need to show where the peak frequencies are (if there are any). I’ve stumbled across Open Sound Meter which so far has been a breathe of fresh air due to its simplicity, but if there are better options I’m open to it.
Has anyone here tackled a similar project or have experience with microphones and setups suited for detecting high-pitched sounds? Any recommendations or tips would be greatly appreciated!
Some of these lights are smart lights and emit some EMF, so a setup that’s not prone to EMF interference would also be ideal.
Thanks in advance!
Thanks in advance!
