I'm no engineer but I think the difference from me switching to the mc611's is the dynamic headroom provided by the amps! At low volume with the meters bouncing between .06 and .6 of a watt music now has some foot tapping weight that just wasn't there with the lower rated amps.
Thank you
@steve59, No, not Dynamic Headroom, why, the meters indicate
0.06W/Min to
0.6W/Max of Power/W for the (played) Music, don’t they?
Let’s look at this a little more closely/further, for consideration….
- Kef Blade Meta 2 Speaker SPL/Sensetivety = 86dB/2.83V/1W/1m, Listening Position = 3m
- Max Listening Level/Transient Peaks = 74.2db/SPL of 86dB/0.6W/3m (Listening Position)
- Min Listening Level = 64.2db/SPL of 86dB/0.06W/3m (Listening Position)
- Allowing for 20db Listening Headroom below Transient Peaks = 54.2db/SPL of 86dB/0.006W/3m (Listening Position)
To accommodate Transient Peaks and for 74.2db/SPL of 86dB/
0.6W/3m, Dynamic headroom is not needed, is it? Even a
1W Amp (as indicated by the 86dB/Speaker Sensetivety/3m Listening Position) can deliver the required Wattage with more Listening Headroom than required, can’t it?
- To be concise & precise, for Max Listening Level/Transient Peaks of 86db/SPL & 3m Listening Position, you only need a 10W Amp but once the Max Listening Level/Transient Peaks are >86db then the required Amp doubles in Wattage every 3db for Max Listening Level/Transient Peaks where…. 89dB/20W, 92dB/40W, 95dB/80W, 98dB/160W, 101dB/320W (it has been suggested this is where the magic begins, for Transient Peaks/Apparently), etc, reasonable?
- Hence the saying, ‘Speaker Sensetivety/Gain trumps Amplifyer Power/Gain’, but there other sayings, such as ‘First Watt’ and ‘Watts are now (dirt) cheap’, reasonable?
Re music now has some foot tapping weight that just wasn't there with the lower rated amps…. it can be suggested, and hopefully, that this is to do with the presented Music
Contrast of the (Recorded) Music that you are playing and not to do with Dynamic Headroom (as suggested above). Where to look for the reason….
- First can you clarify what you mean by ‘lower rated amps’?
- McIntosh mc611 specs…. THD = 0.005%, SNR = 124dB/Balanced or 120dB/Unbalanced (both Exceptional), and FR +/-0.25dB 20Hz/20kHz (Exceptional, very Linear)
- Kef Blade Meta 2/Min Impedance/s.... 35-40Hz/3.2R, 80-200Hz/3.5R-3.7R, 600-900Hz/<4R.
- The Amp needs to easyly deliver (ie requires Delivery Headroom below 3.2R) the required current/A without Voltage/V Drooping/Saging (Speakers like to see a Constant Voltage Source, don’t they?), reasonable?
- The Amp requires Matching/Compatablety with the Device Feeding where….
- if its Input Impedance is 20K-50K then (usually) no issues and even 10K is (usually) ok, reasonable?
- it needs to be able to accept the Feeding Devices output Voltage and its output Current, without issue, reasonable?
- Room, for this post/discussion, it is assumed that nothing other than the Amp/s have changed.
Why is Contrast important, especially as all Music is Harmonic Distortion, even the Fundamental is the 1st Harmonic, isn't it? Music must be non-Linear and it is the Harmonic Synergy(Mix)/Harmony that is recorded but/although all (playback) Devices must be Linear and have No Sound/Masking, why, so that we enjoy the Music as recorded/intended, reasonable?
- As such, with the McIntosh mc611, it can be suggested that the 'foot tapping weight' is linked to the presented Contrast of the Recorded Music when played through your System/Setup & Room and how well the Recorded/Played Back Contrast is presented, reasonable?
- Contrast provides Clarity, a Real/Rightness, Delineation, Perception/Recognition, and many other characteristics, especially those that we are familiar with, doesn't it?
