- Joined
- Aug 2, 2020
- Messages
- 1,015
- Likes
- 887
The Purifi modules will work just fine, if you're going Class D, which I have no issues with and would be my preference if I were buying new amps.10 feet from the speakers
Don't bother with the M23, just get the c298The only issue is that the amplifiers are in the open and their encasing is really ugly!
How about Nord Acoustics or NAD M23 v2
Good day, everyone
What kind of amplifier would you recommend for Blade 2 Meta speakers.
Application is for music is for hi definition SACD symphony orchestra music, rock and action and sci-fi 4K movies with lots of dynamic range!
Used to A - AB amplification but want to explore digital amplifiers
Try the Benchmark ampsGood day, everyone
KEF will use complex x-overs to get a flat response and enough resistors(my R105/3's had a +50ct parts in that 4 way x-over) and amps will make an audible difference. Regarding my Blades the Hegel h360, h590 and lastly mc611's all changed the presentation at low and moderate volumes. The massive MC611's offered the best resolution and bass at low volumes so they stayed. I figured if I'm going to pony up for a $30k pair of speakers I might as well try to get what i'm paying for.A proud owner of Blade 2 Metas here(And my 1st post – hello everyone)
I own Blade 2 Metas with NAD M23 and NAD M66. I chose NAD M66 b/c I wanted something more "modern" (not only modern-looking): Tidal Connect, Spotify, DIRAC, display, etc. There isn't that many to choose from, unfortunately. Then I needed to add more power – so I added M23. I considered C298 but I have both of them exposed and I didn't like the idea of having two-completely different looking devices (or rather I liked the idea of two that are from the same line).
Don't get me wrong – they sound great, I love them. It's just that when I heard them at the dealer's they sounded MUCH (much) better with Musical Fidelity NuVista 800.2 . I don't know if it was the room (maybe, mine isn't very well suited for listening sessions, I will be moving soon) but I wonder sometimes whether it wasn't the NuVista after all that was making the difference.
I have the ATI 542 hypex dual differential amp and it is pretty faultless. Note that ATI uses linear power supplies, not switch mode. They are still big and heavy. It is powerful, neutral and reliable. It has powered everything from Kef to spendors. Recommended!I haven't heard the recent offerings from class d amps. The ATI 542 is a 500 wpc hypex nc. Personally I did find the original Blades to be sensitive to source, especially at low volume and went with the MC611's from Mac. might be overkill, but speakers dynamics are very good even at low volume.
So you chose double MC611 over H590? I heard good things about Hegel (also, it's all-in-one which is also an advantage for me; I'm big not-fan of McIntosh designKEF will use complex x-overs to get a flat response and enough resistors(my R105/3's had a +50ct parts in that 4 way x-over) and amps will make an audible difference. Regarding my Blades the Hegel h360, h590 and lastly mc611's all changed the presentation at low and moderate volumes. The massive MC611's offered the best resolution and bass at low volumes so they stayed. I figured if I'm going to pony up for a $30k pair of speakers I might as well try to get what i'm paying for.
Maybe not enough power?A proud owner of Blade 2 Metas here(And my 1st post – hello everyone)
They are so ugly!Yes, the Benchmark as monos work fine in such a setup but the Buckeye is much cheaper.
Not the same model but looking at these measurements I'm not sure I'd be going anywhere near that brandI heard good things about Hegel
www.audiosciencereview.com
How about Pass Lab 30.8?
According to spec it's 380W into 4Ohm. That should be enough for the Blades.Maybe not enough power?
Benchmark monos.They are so ugly!
They are in the open so esthetic is important.
What do you use?
No! You think?The only issue is that the amplifiers are in the open and their encasing is really ugly!
How about Nord Acoustic have they been measured by Amir or other reputable sources?No! You think?
I think my Buckeye looks the business.
Alternatively, hide then. They are just amps, after all.
Better than Purify?Benchmark monos.
