- Thread Starter
- #201
LOLIf they have a signature it is written in invisible ink.
Not yet, but will try tomorrow. How much you suggest I should spend? Will $100k be enough or no?so you're driving your $30k speakers with a $600 amp/pre/dac? I'm sure you'll love it.
Make sure you familiarize yourself with how the amp handles full volume.Not yet, but will try tomorrow. How much you suggest I should spend? Will $100k be enough or no?
Easy load for what spl at what distance?What's people opinion on driving big Blades One with Wiim Amp Ultra? Blade One is relatively easy load with 91db sensitivity, I have non-meta version, but from what I remeber sensitivity should be similar, thugh at least old ones dip to 2 ohm at some frequencies. I'm currently have Bel Canto/Densen combo, but want to switch to hardware with Tidal Connect and room EQ capabilities. I impluse bought Wiim Amp Ultra already which should arrive tomorrow, the other option I consider is to get Bluesound Node (non-icon) and pair it with one of the Apollon stereo amps, but it's like 4 times the price of Wiim
That is at least the correct way round. Spend money on speakers, not electronics. If the amp has enough power it will sound as good as any other amp with enough power.so you're driving your $30k speakers with a $600 amp/pre/dac? I'm sure you'll love it.
say the distance is 2.5m and I don't listen loud, last time I measured spl while listening music, it was peaking at 85-86 db, rarely at 90Easy load for what spl at what distance?
lyngdorf.steinwaylyngdorf.com
Under those circumstances, the Wiim has more than enough power. At your high end of 90dB** you might be peaking at around 100W (even with 10dB headroom for transients)say the distance is 2.5m and I don't listen loud, last time I measured spl while listening music, it was peaking at 85-86 db, rarely at 90
Looks like you need some subs. It's really like chicken and beef type of difference. Even with the biggest towers.While the Blades are a bit easier load than the Salon 2's I nearly sold my pair of blades also because the music was lacking the low volume dynamics with so many different amps I tried.
Sounds like the amp should be sufficient. I used to play stuff a lot louder than that, but more in that range these dayssay the distance is 2.5m and I don't listen loud, last time I measured spl while listening music, it was peaking at 85-86 db, rarely at 90
How does it sound? The Ultra has a reasonable amount of power. For a reasonable price, a Hypex or Purifi amp provides a lot of power, taking that off the table.Not yet, but will try tomorrow. How much you suggest I should spend? Will $100k be enough or no?
www.audiosciencereview.com
