Hello you all. I need help for an unusual application. We have this super nice commercial induction wok cooktop:
This thing runs in 240 volts and is able to produce heat that no home gas stove can remotely replicate. Problem I have is that with any high carbon steel wok, it will error out complaining that it is an incompatible pot. I have tried a number of them and they all error out. Non-stick, stainless woks, etc. work but not cast iron.
I have figured out that if I elevate the work about 1/8 to 1/4 inch, it will happily work. Initially I used folded paper towel and while that worked, the tower starts to gradually char and creates foul smell which I assume is from the binders in it.
I then bought some silicon mat that is rated to 600 degrees. This worked up to a point and then started to melt, making a mess. I assume something other than silicone is in there.
I bought another silicon mat that they sold for use on barbeque grill. I figured this would work well seeing how they show it on top of open flame:
Oh my gosh... This mat worked for a bit and then started to steam/smoke. I picked up the wok and a nightmare occurred: particles of fine, orange powder pigment started to dislodge itself and stick to everything as it cooled off. Took me entire evening to clean/sand off from the wok.
Today I tried some carbon fiber welding mat rated to some 1800 degrees:
Strangely this one started to steam (?) and produce a bit of white smoke and moisture. And terrible smell. I figured this can't be good to breath so I stopped.
Wanted to try fiberglass but one seller said it was not food safe. Ceramic fiber insulators say you shouldn't breath the fibers so not sure if that is a good option.
I have not measured the temperature of the work but I think it easily hits 1000 degrees and even higher. Anybody can think of an insulator that won't out gas like these things do?
Appreciate any pointers.
