hyperplanar
Sorry, I've never used VoiceMeeter personally, so I'm not too familiar with the specifics. That being said, if Spotify is your main music source, it makes sense to set the default sample rate to 44.1 kHz. You'll avoid the possibility of >0 dBFS peaks produced by resampling getting clipped/limited somewhere in the Windows audio subsystem.Do you think going through VoiceMeeter change something in this regard?
Does it means VoiceMeeter, if used and to be optimized with Spotify, needs to be set with "Preferred Main SampleRate" of 44100Hz?
Will that be at the expense of other application sources which play higher sampling rates?
Is it relevant assuming that Spotify doesn't open the VoiceMeeter VAIO in exclusive mode?
This does mean that higher sample rate sources will get resampled down to 44.1 kHz, but these "high res" sources tend to have a lot of headroom anyway, so it's less likely that you'll get clipped resampled peaks. On the other hand, tons of music on Spotify is mastered as hot as possible and has little headroom.
