Looking to potentially upgrade from my NAD 3020 V2. I don't upgrade often so what something that will last for a while, but is a meaningful enough upgrade from the basic NAD.
My listening tends to be 75% Spotify Connect (via Wiim Mini) and 25% Vinyl (old Rega Planar 2 w. NAD PP1 phono).
Mostly electronic and jazz styles and typically lower-mid volume. Room is a small 10x15ft space.
I prefer something in a slim case design and since the NAD is class-D, thought it might be time to move to class-A/B for something different, and since most of my listening is via streaming I would really want something with the "best" sounding integrated DAC (not interested in a separate DAC).
Not sure these first two would be a huge upgrade, but very well reviewed:
Audiolab 6000a - $750
Rotel A12 mk2 - $850
Stepping up to about as much as I want to spend at the moment would be:
Rotel A14 mk2 - $1200
Or really pushing my budget to the new:
Audiolab 7000a - $1750
Do you think I will get any real appreciable sound quality improvement with an upgrade to make the cost worth it?
Currently using Q Acoustic 3020's (no sub), but trialing Wharfedale 4.1, Wharfedale Denton 85th, Dali Oberon 3 for a potential upgrade.
Thanks! in advance.
Thanks! in advance.
