While the step responses on the SVS "looks bad" I don't know how audible it really is. FR is more audible that time domain issues and if you look at the step response of a crossover it also "looks bad" but sounds fine. That is why I am trying to understand how filters affect the "cone movement" to help me understand what I am looking at. The way I am looking at it is that time domain issues are not as audible as they look on a graph but the technology exists to easily have both good FR and good time domain performance if you are willing to give up "small size". "Hoffman's Iron law" is apparently one of the laws of nature. .Pics of my SB-1000 vs my 15" DIY sub from same measuring session dialing in 4-way XO:
SVS
DIY 15"
That looks better, what allpass filters are you using? I have a PC based system so Taps are not an issue.FWIW, if you have good measurements (i.e. not corrupted by room modes) and a way to apply somewhat long FIR filters, you could correct the SVS's excess phase. Here's an example illustrating the time-domain response compared to a minimum phase model (based on @levimax's measurements)—
Magnitude:
Phase:
Group delay:
Impulse:
www.audiosciencereview.com
The design is to maximise low end in a small package and then cross to main speakers at a typical (say 60-100Hz). It's basically the design of every single svs sub ever (albeit perhaps not in a small package for some of them) and they are generally successful at achieving that goal. Comparing that to a DIY sub which is likely a raw driver in a box with either no dsp or minimal dsp (as opposed to custom dsp designed to maximise output and compress when overloaded without letting out the magic smoke) is going to produce different IRs.Maybe I am being paranoid and not understanding but it seems like a terrible result to have ringing that strong and long
Thank you, I read through the article and need to do so several more times to grasp it better. A question that popped into my mind when reading this is about "steady state" vs "transient". It was my understanding that an impulse response shows the "transient" behavior of a system even though based on steady state measurements but after reading the article I think one of the points was that is not correct and an impulse response is just another view of a steady state measurement and not necessarily representative of the transient behavior of the system. Is that correct?I would hate to complicate it any further, but there's also this:
What is group delay?
As long as they're all showing up at the same time, should not make a difference, n'est pas? So long as there was not a specified arrival time, then yes.www.audiosciencereview.com
The last picture in the above post may be very informative but I suggest reading all of it for a better context.
I agree SVS is looking at the fact that people are close to deaf at LF (80 dB threshold of hearing @ 20 Hz) so 100 ms GD and 40% THD @ 20 Hz are not really audible and they design their subs to be as small as possible (size is the biggest barrier to sales) that can meet these distortion thresholds with as high a SPL as possible when crossed at normal consumer points. As you say this is good engineering and they execute well.The design is to maximise low end in a small package and then cross to main speakers at a typical (say 60-100Hz). It's basically the design of every single svs sub ever (albeit perhaps not in a small package for some of them) and they are generally successful at achieving that goal. Comparing that to a DIY sub which is likely a raw driver in a box with either no dsp or minimal dsp (as opposed to custom dsp designed to maximise output and compress when overloaded without letting out the magic smoke) is going to produce different IRs.
Personally, having owned and tuned all of those sorts of subs over the years, am sceptical such differences matter much (whereas differences in extension/raw output level are plainly audible).
How did you get to 8?Since this is a hobby is this approach really "Hi-Fi"? People seem to be concerned about SINAD over 100 for their electronics but subs with a SINAD of 8 are fine. It seems like a disconnect to me but if viewed strictly from an audibility perspective maybe SINAD of 8 is all you need for a sub?
8 is 40% THD at 20 Hz.... looking again at the Nuyes test the SVS SB3000 had 35% THD at 20 Hz at 95 dB so the be fair SINAD of 9 is more like it. I am not convinced the push to advertise the lowest extension and highest SPL with the smallest size is the optimum for Hi-Fi. At some point smoothly rolled off lows can sound better than highly distorted lows.How did you get to 8?
Regardless of the number clearly it's not an end game setup in absolute terms but you surely need significantly larger subs to achieve the same via native response and that is often physically impossible or impractical/unacceptable in a given room and/or prohibitively expensive so it may well be the highest fidelity you can achieve
I generated those plots a while ago (for a rather tedious argument about minimum phase and absolute polarity) and didn't record the exact parameters. I remembered it being fairly simple though, so I derived parameters again: two 2nd-order allpass filters with a center frequency of 19Hz and a Q of 0.8 fits the excess phase pretty well. Applying the time-reversed allpass cascade to your measurements results in this—That looks better, what allpass filters are you using? I have a PC based system so Taps are not an issue.
Below are the frequency responses of a LR2 (2nd order Linkwitz-Riley) high pass filter, a LR 2 low pass filter, both with 1 kHz cutoff, and the summation response of these 2 filters. There is a deep null at exactly 1 kHz, as per theory.I think you've made an excellent realization.
I'm no bona-fide expert on Fourier analysis, but I understand it well enough to know it assumes/requires a steady state.
Whether we are looking at a transfer function or the impulse response, both are a snapshot in time, that assume a steady state.
Here's a really interesting experiment from the author F.Monteiro, of Crosslite+ an advanced measurement & processing simulation program.
The red and blue sine waves are the sides of a LR12 dB/oct crossover at 1kHz.
Normally, the two sides of a LR12 are polarity reversed, which gives a full cancellation at 1kHz. (for a 1kHz crossover)
In this example, the bold black squiggly line is the two sides 1kHz summation, while both of the sides are being amplitude modulated by a 100Hz wave.
The idea is that the 100Hz modulation is a simple form of introducing transient behavior into a summation measurement.
If the bold black like were straight flat across the example, modulation would have no effect. With the two sides showing full cancellation over the entire 100Hz period.
But note how the bold black only approaches being fully flat when the sines are cresting.
Any deviation from a flat zero summed response in the bold black line, is response bleeding past the full cancellation. Fourier analysis leads us to think such doesn't happen, again assuming steady state.
Hey, is music steady state or transient modulated?? ... i say hmmmm, as always I got some more thinking to do![]()
sin(f1 t)×sin(f2 t) = ( cos((f1−f2)t) - cos((f1+f2)t) ) / 2 ]And the reason it looks like it cancels cyclically is because of the cyclical constructive/destructive interference ("beating") of the two components. The beat is at twice the frequency of the modulating signal, exactly as expected from the two frequency components (1100Hz-900Hz=200Hz).However, the spectrum of the amplitude modulated signal shows it has 2 frequency components, F_signal - F_AM, and F_signal + F_AM, or 900 Hz and 1100 Hz. These 2 frequency components therefore do not get perfectly nulled by the two summed filters.
it's true but it's also true that a sub that plays 20Hz, even with a decent chunk of distortion, at a decent level will *feel* materially different to one that doesn't (emphasis on feel). Whether you're better off moving towards tactile devices (there's a rich vein of DIY devices here that go well into massive overkill territory similar to how DIY subs tend to go) in combination with an array of smaller subs is another Q.8 is 40% THD at 20 Hz.... looking again at the Nuyes test the SVS SB3000 had 35% THD at 20 Hz at 95 dB so the be fair SINAD of 9 is more like it. I am not convinced the push to advertise the lowest extension and highest SPL with the smallest size is the optimum for Hi-Fi. At some point smoothly rolled off lows can sound better than highly distorted lows.
Hobbies are all about massive overkill. If you have a massive overkill sub you don't need "tactile devices"it's true but it's also true that a sub that plays 20Hz, even with a decent chunk of distortion, at a decent level will *feel* materially different to one that doesn't (emphasis on feel). Whether you're better off moving towards tactile devices (there's a rich vein of DIY devices here that go well into massive overkill territory similar to how DIY subs tend to go) in combination with an array of smaller subs is another Q.
However, the spectrum of the amplitude modulated signal shows it has 2 frequency components, F_signal - F_AM, and F_signal + F_AM, or 900 Hz and 1100 Hz. These 2 frequency components therefore do not get perfectly nulled by the two summed filters. That's why there is residual signal after the filter. Fourier works just fine.
I think it actually does cancel cyclically. The fellow who presented the slide encouraged us to generate the test signals into a mixer, and measure for ourselves.And the reason it looks like it cancels cyclically
an appropriately designed tactile device can deliver massively more tactile impact than massive overkill subsIf you have a massive overkill sub you don't need "tactile devices"
that's just comparing a bigger sub to a smaller one, The right comparison here is having sufficient smaller subs (or a heterogeneous set of subs) so that they have equivalent output to 1 bigger one (which may in itself have benefits such as not needing 1 massive amp, sharing the load over larger motors in total thus having reduced thermal compression etc).The difference is the "big" sub would have THD <10% instead of the 3 smaller subs playing with 35% distortion
this is certainly true (though, for film soundtracks and in the absence of beq, can actually be quite enjoyable in itself even if it's not accurate)with 35% distortion you will hear the 40 Hz distortion as being louder than the 20 Hz fundamental which is not Hi-Fi and can be audible
