Help me pick speakers for my big room!
these could be build into a wall to avoid wav problems (if that is an option). That's how some do it here in Europe in a similar situation. These are gret, if you use them with a dsp for room correction and eq. The passive crossover is right aligned on phase/time and frequency response, but they can use some eq to flatten the response, certainly in a room.
104dB sensitive? Oh my. How do you manage hiss on something like that?
Speakers will go along the 32' long wall, ~10' from the side walls, and ~12' from each other. The primary listening position is in the middle of the 32' wall on the other side of the room, so ~20' away. I will mainly listen at low-ish volume, say 70 dB (+/- 5dB), and sometimes at medium volume (say 80 dB). I never listen very loud.
The LS60s are a terrible idea, they are one of the most output limited floorstander that Kef makes.
Max SPL measured at 1m: 111 dB
Let's put some science behind this. Here is the compression data from Erin's review:
With the speakers placed against the wall, to acheive 80dB with two speakers at 20' from the listening position, each speaker will be outputing around 86.7dB @ 1m considering room gain, boundary reinforcement and speaker separation. We can see in Erin's chart that the LS60 is down about 1dB at 50Hz and 2.5dB at 40Hz. This may or may not be acceptable to the OP. If not, a subwoofer can be added to address the bass rolloff issue.
One issue the subwoofer will not address is dynamics above 3kHz. Most music these days (and I suspect audio for movies, etc.) is compressed, so I don't think it is a significant issue. However, if the OP plans on listening to a fair amount of uncompressed music (e.g., classical music recordings, older recordings, etc.), it will be an issue. How audible it will be I don't know. I have a pair of LS60s, but in a smaller room, and I have not experienced any noticable issues, even when listening to uncompressed music.
I own a pair of Revel 206 speakers, but I think they may be too small for the room you’re describing. I think I’d boil it down to the KEF R11, Revel 328, and I’d add the MoFi Sourcepoint V10. That’s a big room you’re talking about.
Reactions: CJH
For this space, the OP might consider some of the horn + big woofer speakers that are more common in the home theater world. JTR is the brand I know of, but there are others. These are usually pretty efficient also. The example below is from the JTR website. They make models with 10 and 15 inch woofers also. A 10-inch, 2-way model is $2500 each, while the 3-way jumps to $3500 each.
As a Revel Performa3 F208 owner, speakers like this are the only ones I'd consider as an upgrade. The WAF is low, however.... :cool:
"The Noesis 212RT is a 3-way floor standing loudspeaker equipped with two 12” woofers in a vented enclosure, combined with an ultra-high-end coaxial compression driver fitted on a large, wooden horn with a 60 x 60 coverage pattern.
frequency +/- 3db
35hz-24khz
Sensitivity*
101db (2.0 volts, free air)
Usable Output**
134db (calculated peak 137 – 3db compression)
Recommended Amplification
up to 2000 watts RMS (program)
Impedance
4 ohm
MSRP $4299 EACH"​
My Tune Audio Anima horns are 109dB/watt, I am currently using a Job INTegrated DAC/amp rated at over 100watts and I just tried them with volume set at normal listening level and CD transport stopped and I don't hear any hiss at all unless I put my ear inside the mid horn where there is a slight "rustle" type sound, nothing from the treble horn, though I can't get my ear quite as close.
I also sometimes use them with a classic 40W/channel class AB valve amplifier and have never noticed any hiss at all.
But WAF is actually even smaller than one might think from the photos.
It might actually be a perfect null--physically impossible to boost.
It's true that the 4722 is cheaper and maybe even better in such a space, but I was also considering WAF, and that speaker it's WAF is very low in most cases. I would probally also choose that one, but my girlfriend, who owns a pair of 4367 in her house would not approve it. But at the end i'm more a diy guy on speakers and have a much smaller room so...
About the bold.
To achieve 80dB SPL (let's say C weighted) at what?
Average, max or peaks?
Cause if the 80dB SPL (C) is all you have, average should be at the 60's, at most.
LS60 is already -3dB at the visible chart for 96dB at its edges and it seems that has no output at all for 102dB except the 2 tiny bumps at 1kHz and 2kHz.
Totally unreal for 20 feet and most importantly 450 m³ of room volume and not only for reference level.
So, I'm looking for a pair of speakers for my library which is 23' x 32' x 23' high. Vaulted wood ceiling, wood floor, wood book shelves and 1000's of books + some big and small windows.
Speakers will go along the 32' long wall, ~10' from the side walls, and ~12' from each other. The primary listening position is in the middle of the 32' wall on the other side of the room, so ~20' away. I will mainly listen at low-ish volume, say 70 dB (+/- 5dB), and sometimes at medium volume (say 80 dB). I never listen very loud. I want this to be a reference-on-a-budget system. I am budgeting $6,000 for speakers, but if I can spend 1/2 of that without giving up too much, I'd be happy(er) with that. Hopefully I can find what I want used, but if not, I'll likely be at the top of my price range. I'd prefer not to have subs (WAF concern + sound cohesion concern), but will put 1 or 2 in there if absolutely necessary.
I have a Rivo+ streamer (with an LPS) already, am looking at DACs such as the Denefrips Pontus 15 (but need advice on that ... for a different thread), and a class D amp(s) of 400-600 w @ 8ohms (amp will depend on speakers).
I'd like a neutral but musical sound, a wide and deep soundstage, and good separation of instruments / voices. Ideally, the sound will be immersive, but precise (if that makes sense). My biggest constraint is size/WAF. Have better chance of WAF the smaller I go, but have better chance of filling the space the bigger I go. That's my dilemma. So I have broken down the choices i am looking at below in 2 categories: 1- small towers / big standmounts / higher WAF; 2- medium towers / lower WAF. I will lean heavily towards those that can fill the room without the use of subs.
Cat 1 - smaller size / higher WAF
KEF R7 Meta - 41.8" × 7.9" × 15.1"
Audio First Cadentia 3 - 23.2" × 11.8" × 17.0"
Wharfedale Super Linton - 23.8" × 11.8" × 13.0"
Revel Performa3 F206 (or the 226be) - 41.4" × 9.8" × 13.6"
Paradigm Founder 80F - 38.2" × 11.7" × 14"
Acoustic Energy AE320 - 41.3" × 7.9" × 13.7"
Ascend ELX Tower - 43.0" × 7.5" × 10.5"
Cat 2 - larger size / lower WAF
Philharmonic BMR Tower - 44" H x 12" W x 15-1/2" D
Revel Performa3 F208 (or the 228be) - 46.8" × 13.6" × 15"
Sonus faber Lumina V Amator - 45.3" × 14.6" × 18.7"
KEF R11 Meta - 49.2" x 7.9" x 15.1"
Paradigm Founder 100F - 41.9” x 12.9” x 16.1”
Mofi sourcepoint 888 - 42.1” x 12.6” x 16.1”
Monitor Gold 300 6G - 43.3" x 13.3" x 18.3”
Any thoughts on this list and which of these might fit my parameters? This is already a long list, but I am happy to add to it if someone has a different idea.
For room of your size you need BIG speakers. This will not be cheap. I would say that budget should be $25K-30K for speakers alone. Look at something with at least 15" woofers and rated for 120dB sound pressure. Even that may not be sufficient and additional subs (18"-24") will be required. Anything less will sound small, unless you decide to limit you listening space to one corner of that room.
From speakers which I know personally, I would start with ATC SCM150 ($46000).
Wow, up to $46K speakers already. I'll take a road less travelled. Considering the room size and your esthetic limitations and basically background listening level I wouldn't spend the amount you're considering. Get a couple of Sonos and place them closer to your couch. I don't see the point of spending $15K for background listening levels. I hope this doesn't come across as critical in any way it's simply my two cents for a reasonable outcome taking in all your restrictions.
Perhaps consider the Philharmonic HTs. They can play very loud and are very efficient. In a room that size, you will need a good quality sub.
Next step up from ATC will be JBL DD67000 for $67000. Room size dictates what kind of speakers are needed.
You don't need that kind of money, a JBL 4722 will do it as good, it just won't look that fancy or be hyped that much and kost 2800€ per speaker (x2 for stereo) here in Europe. And if you need deep bass, add the sub of their cinema line that fits your need, the most expenive is like 3K. Money does not equal quality in speakers, so ...
Oops, I missed that page!
Mitch Barnett has been using 4722 for a long time and, as far as I know, has no intention of changing.
I think 4722 are cool speakers, :D but it's up to TS to decide if they fit into the home, WAF and all that.
In any case, large speakers, we also have large ones in the form of long but narrow; line array speakers:
They can also be an alternative to TS, especially because of the large listening distance, which @Mr. Widget talked about in the thread.
Large speakers, if you want them to fit in style in a combined listening, living room, then DIY is something to consider. Build a TV bench with built-in speakers for example to blend in with the rest of the furniture.Line array speakers, there it is probably mostly DIY that is the solution for such.
