So I have been going back and forth a lot on different speaker options lately, with the big limiting factor being that one of the speakers has to fit into a fairly small spot on the desk next to my left arm. The right speaker has various places it can go... it's an L shaped desk with two huge monitors spread across it so yeh it's an awkward layout.
So I'd been looking for particularly compact speakers, which generally meant 4" woofer ones (which for desktop use is fine, if not already overkill), but I want to be able to buy these speakers for the long term and (for the most part) the 'really good' speakers with great build quality and looks along with (ofc) sound seem to start in the 5" region and up. Which concerned me cos I thought maybe that would push the front of the speaker too oppressively close to me.
So I ended up just going to the effort of trying to mock up the common two sizes I had in my shortlist:
Micca MB42x G2, and the RB42, and the Swan 140. All kinda similar in size / depth. This is RB42 length from the wall, so it would be up against the wall, while the MB42x would have a couple inches of gap.
Cambridge Audio SX-50, and Neumi BS5. I actually thought these would be more oppressive than this, but actually in place it seems not so bad. Again, will be up against the wall as much as I can make it.
At which point I'm wondering if this is already pushing things too close, or whether I could start looking at the speakers I'd been skipping, such as:
Wharfedale Diamond 9.1 (not sure if these are any good)
Polk ES15
Elac Debut b5.2
Elac Debut Reference
Kef Q150 ... (I think they can be plugged so maybe they'll work against the wall but idk, if they can work these might be fantastic, I'd liked them early on but dismissed them solely on size... I probably shouldn't get excited by the idea though cos I'm sure someone will tell me they won't work lol)
But yeh, sizing up opens up a lot of nice options that (should) last me a long long time and be more versatile. But ofc if it's going to be a hindrance or a pain using it in my current desk use case then probably not worth it. But I can't easily test it so figured I'd ask the question to the experts! Appreciate any guidance on this!
(PS. And yes, I'm aware the D3V and Kali are probably the sensible desktop choice, I just don't like them. Aesthetics is raising it's ugly head.)
Polk ES15
Elac Debut b5.2
