Update: Going for the Barefoots. Price is now the same as the Twins so there's no point in doing anything else, plus the built-in sanity checking of the MEME system is worth it.
how are the Barefoots now that you had some time with them?
specially with the low bass and low mids?
I have the focal solo6 be and are good but I've moved to a bigger room and im thinking these might be too small. but not sure if adding a bass would be enough or the barefoot has better low end plus clarity of the 3way design.
Basically what some said above, how is the difference from the Focal shape to the barefoot? was it a massive difference?
