Help me get into making vinyl rips myself?
PashkaTLT
New Jersey, USA
I have a large record collection and want to archive my favorites and some rare pressings. My setup is TEAC TN-300 ("upgraded" with an Audio-Technica AT-VM95ML cartridge, an azimuth-adjustable headshell, a record weight, and IsoAcoustics isolation feet). Its built-in USB output is limited to 16/48 and I'm not sure how good its preamp and ADC are.
1. Hardware.
I'm open to buying a dedicated ADC and/or phono preamp, but only if it would actually improve the recordings, and I'm not sure it would. If you think an upgrade is worth it, I'm considering a Behringer UMC202HD fed from the TN-300's line out (PHONO EQ on), recording at 24-bit mainly for headroom and potential editing. Also I wonder if the built-in phono preamp is a weak link. Maybe I'd benefit from a dedicated preamp too? In case of upgrading hardware I'd like to fit in about $100-150 budget for ADC, or $200-250 together with a preamp, if possible.
2. Processing. What does a typical workflow look like: declicking, track splitting, normalization, anything else? I know some people don't do any postprocessing except removing clicks. Which tools do you use, and are there good guides? I'm a programmer, so I'm comfortable with technical material.
3. Cleaning. I have a basic cleaning kit (anti-static record brush, soft velvet record brush, cleaning liquid, stylus cleaner) and would rather not buy an expansive ultrasonic cleaner (although perhaps there are good inexpensive ultrasonic cleaners?). What's the best approach without spending too much? What's your process of cleaning records before recording?
Thanks in advance.
Hi,
The ADC in your turntable will do the job - given the fidelity of vinyl.
I have isolated pops and clicks and diminished their impact using the free Audacity app - but, it has been many years and there may be more efficient methods.
Your simple cleaning kit may be all you need given you know how the records have been stored.
16/48 is way more s/n than records have.
I did several hundred records a while back and am preparing to doa thousand more.
I am doing records I bought used. The biggest task is cleaning. Both the physical cleaning and removing clicks and pops.
I have been testing several apps.
Sony SoundForge v 9, which great, but it’s on an old, slow computer.
SoundForge 26, which I hoped was an upgrade, but which has dropped all the features that made the earlier versions good.
Vinyl Studio,which haven’t tried. It’s supposed to find cover art and split tracks.
Audacity, which is free and has the noiseprint/noise reduction feature that made SoundForge great.
You have to test restoration features. The claims can’t be trusted.
By far the most transparent click removal tool is marking the click in one channel and copying from the other. This works more often than you’d think.
I use Audacity and an old, inexpensive outboard Creative ADC ("Soundblaster mp3+", Model SP0270) that I bought a long time ago for some project for a laptop, FWIW. I have never been dissatisfied by the outcome(s).
Using the same box to, ahem, rip VHS HiFi stereo audio.
I use Reaper for ripping vinyl. Record both sides onto 1 track. Create a region for each song, with song title as region name. Name the track with the album title.
Use these names as wildcards when rendering.
(Wildcards, region, trackname are all Reaper specific terms.)
I have nostalgia for some vinyl stuff I have, but wouldn't call it a preference. Different perhaps. I have had my tt/vinyl for a very long time, am a "collector" of sorts but maybe packrat might be a better description :)!
In any case, I did get a phono preamp with ADC option to digitize the vinyl to get it as good as it gets so to speak....but was still such a tedious process I just decided playing digital largely was more than enough and for nostalgia just putting on the vinyl worked just fine. YMMV.
My understanding is that a good phono preamp will make pops and clicks quieter because they have more headroom and the pop won't distort and gain harmonics. But if you don't have a few hundo to throw at that and a stand alone ADC like a Motu M2 or similar, the advice in the thread so far is solid.
Your audio hardware is "fine" given the inherent flaws of vinyl. However miniDSP ADept will capture at higher resolution for headroom needed for digital "restoration" cleaning up artifacts.
If doing that, record to WAV rather than direct to FLAC.
Tools google says worth checking out:
track splitting and metadata from Discogs VinylFlow
repair VinylStudio, iZotope RX Elements / Standard, ClickRepair, Airwindows DeCrackle
Please search the various threads here about Parks Audio products.
Regarding cleaning, my impression is that the consensus says this is the most effective, and best quality to price ratio, method, if you have the time and energy:
I just want to point out that if you are going to use normalization, you should do it before splitting the tracks, since you probably want to keep the original volume differences between the tracks on the album.
So do any sound processing and enhancements first while you still have headroom, then do overall volume normalization, and finally do editing, like splitting up the tracks.
Wow, 192 pages! That's some work!
