Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
I have a Cambridge Audio AXR100 with a built-in DAC, and it seems like it's broken. I'm trying to decide whether I should buy an external DAC like an SMSL PS200 or try to get it fixed for nearly the same price as the external DAC. What would you do?
Some additional detail would be helpful: what makes you think that the DAC is broken, and only the DAC? A little context on the rest of your system, source to speakers, is always useful too (and interesting)
Sure thing! The reason I think it's broken is that I get no sound from it when I try to use it with a digital input. I tried it with both Bluetooth and optical inputs and I got no sound whatsoever. When I used it with an analog input (RCA jack or radio) it worked fine. I use it with 2 passive speakers (Sonus Faber Lumina 1), and the source is mainly an LG TV with optical output.
@hulcsa It is indeed advisable to do thorough troubleshooting first. It could be a simple mistake, something you overlooked, buried in settings menus, etc.. Happens all the time, to all of us.
There have been a few posts about problems with LG TVs: difficult to find settings, even sensitivity to different cables (don't get expensive ones, just try a different brand).
I'd be a little concerned that both Optical and Bluetooth had problems though. First step would be a deep dive into the manual and settings.
Is your amp still in warranty? If so perhaps a replacement is in order
Thanks for all the responses! I've been using this system for years, and it worked fine with this setup. I tried and looked into every setting, did a factory reset, but nothing worked so far. Works well with RCA Jack though, that is how I am using it right now. The amp is past warranty sadly, and looking at the prices of a new unit of the same kind, I do not intend to replace it just yet. So assuming that the DAC is really broken what would you guys do?
