Help me decide: Akg k702 vs Sennheiser 560s
Which headphone is better for sound design / mixing / critical listeling?
buscon
dear Forum,
I want to buy an open headphone for sound design and mixing. My budget is max 150€ (in Europe).
I narrowed down the choice between the AKG k702 and the Sennheiser 560s and I am auditioning both at home.
I am testing them with and without EQ (Oratory AutoEQ and Sonarworks). I can return both of them without problems.
The problem is, I like them both :)
The K702 definitively needs some EQ to be properly used, the 560s can go without EQ though I do like it better with EQ.
Using the EQ is not a problem in my setup.
They are both comfortable, though I find the K702 more comfortable than the 560s.
Soundwise I tend more toward the 560s.
I think I will be happy and can work well with either of them.
In any case I wanted to hear you opinions about it.
I have the impression that the people of the forum will tend more toward the 560s. I also read the good review of @amirm of the 560s and the reviews of @solderdude , which make me tend even more towards the 560s.
