I would start by using one bass unit for bass and the second (upper) one for mid-range. Better, I think, would be to blank off the lower bass unit, and fit a larger side-mounted bass unit, or better still, two side mounted bass units, so their 'equal and opposite' reactions cancel. A further refinement might be to change the mid-range for a smaller one, as that's likely to improve the dispersion characteristics of the system.I think they are indeed 2.5-way. But does it matter for conversion to actives?
There are two options:
1. with adding a larger bass driver (side firing) - I then use both current drivers as the mid channel. Is it a good implementation? How do I wire them - parallel or series?
2. drivers as is - I assume I connect the mid channel to one and the bass channel to the other.
I could start with option 2. and add a larger bass driver later.
How far you want to go with this depends on your motivation.
S.
