dshreter
- Joined
- Dec 31, 2019
- Messages
- 794
- Likes
- 1,226
From the experiences you’ve described, I have a concern that you’re relating “I hear X bass really clearly, so Y position is effective.” You’re a self proclaimed bass head, so I suspect this experience you’re describing is finding yourself in a node and liking how prominently the bass pops - but don’t mistake this for a good response.
Ideally you want to keep working through the speaker and subwoofer placement until you have a relatively smooth response. And only then you can dial in EQ to increase the bass response to your taste.
One thing to also keep in mind is you will need to adjust the subwoofer phase as you move its location. If phase is set wrong, it can cause all kinds of issues so it can’t be ignored.
Good luck, keep going!
