LegionOfHell
- Joined
- Apr 25, 2021
- Messages
- 151
- Likes
- 11
My setup will be like the following: Creative X7 Lineout ----> tube pre-amp ----> Schiit Heresy.
I have some questions:
(1) First of all, I wanna make sure that I understand what a tube pre-amp does:
(a) it amplifies the outputted signal from X7 a little bit so that the signal strength is compatible with the Heresy's required inputted signal strength.
(b) it distorts the signal by using tubes so that the music sounds more beautiful.
Is my understanding correct ?
(2) I need a cheap tube pre-amp, I am currently looking at this , is this a good tube pre-amp for this setup ? are there other choices in the same price range that are better ?
(3) Is there anything else I should worry about when setting this up ? like, at what volume should X7 and the tube pre-amp be ?
