Drift will almost surely be an issue over 60 minutes with 4 unsynched recorders. At one time Audacity could make very precise speed changes to a few parts per billion to fix such issues. It has less precision in this since a few years ago. There might be other software that could fix it, but I'm not sure right off hand.
Ok, then the H series are out. I reallllly don't want to spend any time syncing tracks. The wireless timecode serves to remedy that, but I don't want to be wondering if the wireless timecode is reliable enough. The lack of monitoring (for me) will also make it impossible for me to set the mics up predictably.
NB: EQ will apply to everything captured, regardless of angle.
True, I had a brainfart there.
Since we've moved towards outdoors/acoustic/battery-powered, this pair of articles will be valuable reading:
[...]Read More...
www.audiotechnology.com
[...]Read More...
Since those were written, iPads have been upgraded with USB-C connectors, which expand their capabilities considerably: my iPad Mini 6th gen can directly power a Behringer UMC404HD, which has inputs for 4x real microphones. Far better performance than a Zoom H-series.
Alternatively, if I introduce a USB hub with Power Delivery, I can use a USB battery to power everything.
Higher channel count interfaces are available, of course, but you end up moving towards mains (or DC, which can be okay if you have a suitable battery for that) powered devices, which reduce portability.
Finally, you could look at the Zoom F6, which has 6x mic inputs in a neat little box, and can also be externally powered.
I know all of these solutions are more expensive than a couple of handheld recorders, but IMO the improvements in sound quality and usability are too great to ignore.
The articles are interesting. For audio he either uses a Zoom F6 or a Nagra Seven (2 inputs).
My minimal requirement is 8 inputs. A mobile power source is then indeed a must. The Zoom F8 does everything, and doesn't break the bank at below 1k.
I'm organising my thought process below:
The options
There are 3 viable options:
1. Laptop / Tablet + Interface (ex: Laptop + any 8 XLR interface)
2. Field recorder (ex: Zoom F8)
3. Mixer-recorder (ex: Zoom Livetrak 20)
Pros and cons
1. Laptop/ Tablet + Interface
Pro: Ability to properly mix without transferring files.
Con: The least reliable. (Ie. Unexpected updates, dropouts). Laptops aren’t weatherproof.
I have also never gelled with tablets. That’s a bit irrational but I just don’t like the feel of working with one.
Pro: Solid as a brick, efficient workflow
Con: No multiple headphone/monitor mixes.
Pro: Easy to work with Headphone monitor mixes. Has use in other projects.
Con: Takes up space, not weatherproof.
Weighing the Pros and Cons
I don't like the laptop or tablet route anymore. It's not robust enough.
The field recorder is the clear winner IF I'm sticking to the "no monitor mixes" thing.
However, I think I should reconsider. Acoustic acts still want to record with a click, with a prerecorded drum part, scratch vocal or vocal harmony.
The Zoom Livetrak mixer-recorders are also a good alternative. Especially the “rack” mounted version has nice carrying handles, and a compact form because of the omission of the faders.
Zoom ontwerpt en produceert een uitgebreid assortiment recorders, multi-effectprocessors, effectpedalen, drummachines, digitale mixers en samplers. Onze i…
www.zoom-europe.com
Livetrak L-20R vs F8
Equivalent input noise Actual measurements: −128dB EIN (IHF-A) at +60dB/150Ω input
Power AD-19 AC adapter (DC12V 2A)
Power consumption 24 W maximum
External dimensions 438 mm (W) × 158.2 mm (D) × 151.7 mm (H)
Weight (main unit only) 2.49 kg
The Livetrak records all channels to SD, but is also flexible to record to a DAW in interface mode. The Zoom F8 is more robust in that it records to two SD’s for redundancy, and in 32bit float, where the Livetrak records to one SD and in 24bit fixed. I don't need all 20 inputs, but the smaller versions of the Livetrak have faders and end up not being that much smaller.
Powerstation
A compact mobile power station like this will power this for at least 10 hours
The Jackery Explorer 300 is the ideal portable power station for short camping trips, off-grid living, and for powering small appliances when power outages.
www.jackery.com
It weighs about 3.5kg, size is 23x20x13cm. Capacity is 293Wh
(Operational time: 293Wh / 24W = 12.2 hrs)
Monitoring
Giving the band headphones goes against the "nature" look I'm going for (there will be an optional video shooting service too), but wireless IEM's are invisible enough.
Total kit
The total weight of this is 6kg. The volume of the mxier is 10L, of the powerstation 6L. I can easily pack this in a 60L hiking backpack.
Then add 4 mics with wind filters, 6 wireless IEM's, and hang the 4 mic stands and the 8 XLR cables on the outside.
If I'm not forgetting something, this seems like a robust and mobile kit.
Note: The Zoom devices mentioned are not "final", they serve as placeholders for the idea. I haven't checked if brands like Tascam offer similar products but I will.
Curious if you guys see mistakes in my reasoning or otherwise. Thanks again for reading this and for the input.
