Can someone explain the phase issue here?
Is there an issue? Just looks like the phase of a two way with 2nd order filters.
hi there,@Vuki @suttondesign How do they perform in terms of spatial envelopment? Do they present a wide soundstage, or does the sound feel more like it’s coming from a single point in space?
I’m looking to upgrade from Yamaha HS8s, whose wide horizontal dispersion I really enjoy. I’ve tried a few pricier 5–6″ models with narrower dispersion; while I preferred their tonality, I couldn’t live with the more ‘pinpoint’ presentation.
From Heissmann’s directivity measurements, it looks like these sit somewhere between ‘wide’ and ‘narrow.’ Does that match your experience?
Also, would you describe their voicing as more on the warm or the bright side?
Thanks.
Great job on the build. What did the crossover parts cost? Did the metal bracing come from the hardware store?Pretty much done. Haven't tested them yet. Waiting on finish to cure. A couple of cosmetic flaws. No one would mistake them for high-end factory-made, but they certainly do look hand-made, which is not nothing.
$378, plus I paid $25 for the plexiglass onto which I mounted the x-overs, and then about $30 for the Wago connectors.Great job on the build. What did the crossover parts cost? Did the metal bracing come from the hardware store?
Can you provide some additional insight w.r.t. potential DXT differences:The only complaint I have is that the DXT-Mon series was designed with a different batch of seas dxt tweeter and would need crossover rework.
"Applied a 4db boost at 2360hz with a Q of 2"
Yeah, I basically did the similar as suttondesign wrote but one should not have to.
I am building a pair of these right now. Curious about the replies.Can you provide some additional insight w.r.t. potential DXT differences:
- is there a way to identify which "batch" DXT one is using?
- has Heissmann acknowledged this anomaly?
- is there a documented/known design change to adjust the crossover for a different DXT?
- does this issue carry through all his DXT designs (esp DXT-Mon-RNX)?
I am planning a DXT-Mon-182 build and have acquired the drivers and cabinet materials, but haven't yet acquired the crossover components. Hence I am curious/concerned if I should potentially implement any changes to the crossover based on your claims/observations w.r.t. the DXT production runs.
The first DXT-Mon (original smaller model) a former DIY Fellow built was exactly like the original. Mine and all other I have seen thereafter are different regarding tweeter response.AFAIK all the talk of tweeter batches is just total speculation by forum users. It all seems to be based on one persons build that was shared here. I'm not aware of revisions to the DXT aside from different dome materials that I think only Grimm is using. What is more likely the cause of the differences is issues with the builders analysis tools or measurement environment. We don't have all the info from the builder, like were they using a cal file for their measurements. My mic for instance shows a similar dip without it's cal file.
How is the sound compared to the cadentia?Following up on this thread, I built the attached speaker from the Heissmann plans but also wanted to keep the crossovers outboard. So I transferred them from plexiglass and slimmed them down a bit onto a piece of hardboard, then built boxes that match the speaker and are the same footprint. I am awaiting speaker terminals for the back panel; the crossover connects to the speaker via Neutrik 4-channel connectors. The holes allow air movement.
Now I have to decide whether to keep them or sell them. I've built the Cadentia 3, but it's quite a bit larger. Since I have dual-opposed subs, not sure if I need the larger Cadentia.
I've been waiting to get these boxes built before doing the head-to-head comparo. Stay tuned!How is the sound compared to the cadentia?
