Disgruntled H95 owner here. I must admit that I bought into the Hegel PR garbage of distortion free / pure / clean sound. SoundEngine2 feed-forward nonsense. I even convinced myself the DAC was good!
I auditioned 5 different amps at my house (including a 'perfect' class-D with enormous amount of global feedback) and after lots of effort decided that I liked the H95 the best. Disclaimer, I am a sucker for all-in-one solutions, I even use the headphone output on this thing.
Anyway, after reading this thread I can no longer listen the noisy hunk of junk in my rack.
I hate it everything about it now, funny how your brain works. It's on eBay already.
The question is what the hell I should get now. I spent so much time landing on the H95, can't go though the audition agony/expense again.
Giving up on music is probably the correct answer.
// Annoyed Hegel customer
Oh my ... this note gives me pause. If you enjoyed the sound of the Hegel H95 for quite awhile why would a test result article change your mind? Can you be so easily led to another path simply by reading something? The way an item is tested may impact the results and audio test numbers do not always translate into a difference in sound quality.
Let me offer an example:
I have two units in my office. The Hegel H90 (previous version of H95) and the RME ADI-2 DAC with a 200W per channel amp. I have been comparing both units using my BMR Monitors in this 12'x13' room. The ADI-2 DAC has a very positive ASR review while the Hegel H95 was just rated poorly by ASR. However, when I switch between these units with the BMR monitors the sound difference is minor to my ears. I am quite happy listening to music on either system.
The Hegel H90 offers a single box that does it all. It's not very expandable as the "variable line out" doesn't offer enough gain but it sounds great using the USB input with the BMR speakers. I bought it on sale for $1259.
The RME ADI-2 offers more power choices and the 200W amp I have attached is 3x the 60W internal Hegel H90 amp but both still sound really close at 70-80dB volumes. I spent $1299 on the RME ADI-2 DAC and obviously more for the external amp. This setup takes up a bit more room and uses several boxes/cables but sounds great too.
The RME ADI-2 is more customizable but for my listening pleasure I'm totally happy listening to either unit. My advice is don't jump down the rabbit hole chasing better measurements. If you change equipment every time you read a review you'll never be satisfied and the process will empty your wallet for little to no additional sound quality. Frankly, you may end up with something you like even less after using it for awhile.
ps .. how much do you want for the H95. I may be interested in a deal.
