DavyRockstar
- Joined
- Feb 15, 2023
- Messages
- 23
- Likes
- 5
well, i'll try to explain myselfCan you tell me then why so many people raved about Marantz's warm sound? ASR has reviewed at least half a dozen of Marantz AVRs (2 that I can remember), 2 each of the AV7705 and AV8805, among others, please show me which one of them shows more second order harmonics than the 3rd, 5th, 7th etc. If you cannot, then I would suggest you add one more important thing that's been happening, mind tricks!! What I said about the Marantz example, probably applied to Hegel's too. Food for thought, if the total harmonics amount to less than say 0.05%, that is -66.5 dB, does it better too much whether that's made of 2nd to 3rd harmonics in a 2:1, or 1:2 ratio? Same point on bass, I have never seen any Hegel, Marantz, or any so called warm AVRs, AVPs, integrated amp, power amps that have +3 dB boost in all bass region, let alone the whopping +12 dB you used as example. That could be possible in some old single ended valve amps, not the modern ones like McIntosh's or Luxman's.
To be clear, I agree you are right that second harmonics and some sort of bass boost could give people the perception of "warmth", I am just saying because of this being very highly one of the main reason, the other main reason is also people's mind are easily tricked, seemingly anyway.
first i think what people refer as warm sounding is not a general balance in bass region but the balance in the mid range section, as far as i understand a warm sounding amp is the one that adds a touch of mid bass to the mids, so the voices sounds "warmer" but the rest of the bass remains in balance... as an owner of the marantz 2230 and FR4000 (the vintage unit) they tend to sound warm but this is because they lack of services, but after a recap non of this units sounds "warm" in the first place, most people think "there is a warm to the touch" 'cause the the unit is opaque due to the lack of services such as recap or dirty potenciometers and switches.... my 2230 is crispy clear in sound even a little bit sparkly in top. the other reason of this warmth is 'cause everyone uses loudness all the time, and for my 2230 is like +10dB in bass and +6dB in treble (there is no way to know this with certainty, just my ear), after service i don't use loudness anymore the treble gets aggressive with my speakers...
now, in my Marantz 2230, FR4000, kenwood KA-880D, and Nakamichi amplifier one, the mid range section i feel they are quiet the same in tonality with great balance, but the Nak feels cleaner slighty more forward, detailed but less harsh at the same time at high volumes compared to the other units, and this is why it is my main amp
i was an owner of a Yamaha Rs300 very lean amplifier, slightly leaner than the other units and also a coldness in the mid range section (but once you use loudness you can wake up and see the power of the unit and in my opinion you can get a good sinergy with most speakers)
i also have a pioneer elite AVR in stereo config, don't remember the model; paired with a topping E30 DAC, refference vintage infinity speakers, speakers that i tested with other amps, and well this amp in flat is quiet bass heavy but the mid range section is not warm at all, and i like how the system sounds flat without any EQ fix
But the fact that in general balance a Hegel amp sounds more powerfull in bass, "more autoritarian" (i think is how peaople describe it) than my Kenwood with loudness on, but at the same time such a refinement, that you don't really feel what is going on you just see the cones moving like crazy at relatively low volumes and that "dark background" (dark background that the kenwood with loudness almost achieves) makes me think there is something goin' on with the signal and i belive is in the preamp section of these Hegel amplifiers
So far i think the Hegel sound is my favorite amog all recievers that i have ever listen to, and as i said before i use a +10dB curve using DSP EQ, my main source being my computer using a PRO-JECT (pro box s2 digital) DAC and while i get the bass there is a lot that can't be obtained with just EQ
i also listened to a NAD M10 and it felt bloated (with flat sound, but can't tell if there was EQ going on) to me specially compared vs a Hegel amp
