bennybbbx
for a desktop and on side of a 32 zoll monitor in distance of 60 cm, i can not place 8 Zoll speakers. The kali lp6 is the maximumn size i. better is a 5 zoll that can reach 48-50 hz -3 db(because many base drums use this frequency). the kali is 12 db below that on my room.
thes specs of the hedd 05
Frequency response 45Hz - 50kHz
Frequency response ± 1.5dB 52Hz - 20kHz
THD 90dB/1m > 100Hz ≤0.5%
Max SPL sine wave 100Hz - 3kHz /1m ≥103dB
Max SPL peak per pair at 1m ≥111dB C
Crossover frequency 2.3kHz
Weight 7kg (15.5lbs.) Dimensions W x H x D 180mm x 308mm x 228mm)
https://www.hedd.audio/wp-content/downloads/HEDD-Type05-Manual.pdf
My kali reach on 100 hz sine tone only max 84 db on my hearing position(only 60 cm away) measure with my sound level meter. in hedd 05 spec stand >103 db with 100 hz too.
it look as a physical dream that such small speakers can go so low and so loud. the only negative side is the price. the hedd 05 cost over 850 $ a pair. so are there maybe other cheaper speakers out that have 6.5 zoll or less and can reach this ?. or are maybe the specs not correct ?. there is a test in italian but can see a frequency diagram that is a dream for 5 and 6 zoll speakers. http://nuke.nonsoloaudiofili.com/HEDDType05SeriesONENearfieldStudioMonitor/tabid/504/Default.aspx
