Jacksoneptali86
- Joined
- Oct 19, 2025
- Messages
- 2
- Likes
- 0
Hi, I have Tidal + USB Audio Player Pro (avoid resampling on Android) + IFi Hip DAC 3. I'm about to buy some open-back headphones, which ones do you recommend? My budget is up to $500. I had in mind: Beyerdynamic DT 1990 Pro, HiFiman Sundara, Fiio T11 Pro, Ak Pro Audio K7, Audio Technica ATH R70XA I'm not sure if any of these models would be good or which one you recommend. My preferred music genres are electronica and EDM.
In the country where I live, it's very difficult to get hearing aids of this quality, and they're expensive. Not to mention refurbished or used ones, it's almost impossible to bring them in because they end up costing almost as much as new ones. For this reason, I'm asking for your help to review which ones might be the most suitable.
