I'm looking for headphones that exhibit minimal rolloff with an imperfect seal, extended low distortion bass, low placement variation and a lack of any high-Q peaks or cancellations. In terms of FR I find myself liking flat or very slight shelved up bass (rising slightly lower in frequency than Harman does, and with less boost), so even with reasonable amounts of leakage it stays flat. And pinna gain matching Harman till 2kHz, then staying about 1.5-2dB lower than Harman till ~7kHz when it can start to approach Harman levels again.
The way I see it is that in the absence of full body vibrations, what (mid)bass headphones have should at least excel in FR and distortion, which a HD650 couldn't do it for me. I don't need extreme 20Hz rumble but I expect exemplary performance down to ~30Hz.
Candidates I have are essentially the Meze Empyrean for its exceptionally smooth and consistent pinna gain, or Audeze LCD-3 (seems to be the smoothest LCD headphone with least odd-shaped and high-Q FR features). The Empyrean needs significantly less EQ than the LCD-3, but has higher distortion in the midrange and some low-Q resonances in the midrange vs Audeze. Even though my gut feel is that these low-Q resonances are in a range where leakage doesn't affect it, but are also of a large enough wavelength that placement variation is low (compared to the treble, making EQ likely straightforward) is there anything like an Empyrean, but lower midrange distortion, no low-Q midrange resonances, and more energy 1-2kHz?
The Meze Elite seems like one step forward and two steps back - lower midrange distortion, but also a shelved down subbass, more prominent 1-2kHz dip and more prominent low-Q resonances throughout the midrange, so I'm not keen at all about it unless the placement variation is so low that all of those issues can be reliably EQ'd out.
Dan Clark's headphones are wonderful with a perfect seal, especially with ergonomics, build and midrange tuning, but the fairly high-Q (but also high enough magnitude to be readily audible) 6kHz peak and sensitivity to imperfect seal are more problematic IMO than either Audeze or the Empy.
The Audeze MM-500 looks very promising, but no distortion measurements yet and the upper end of the pinna gain doesn't seem as smooth at the Empyrean.
The Stax SR-007 also looks a good fit tonally but placement variance seems to be a lot higher. And I live on the Equator with 90+% humidity constantly so any electrostat will need babying.
My requirements (especially regarding seal sensitivity, placement invariance and extension) seem to favour planar drivers but I'm also happy to consider any dynamic candidates.
